fpga mem virtual address is 0xd2000000
2022-01-31 09:51:35 driver-btm-api.c:663:init_freq_mode: This is scan-user version
2022-01-31 09:51:35 driver-btm-api.c:2028:bitmain_soc_init: opt_multi_version = 1
2022-01-31 09:51:35 driver-btm-api.c:2029:bitmain_soc_init: opt_bitmain_ab = 1
2022-01-31 09:51:35 driver-btm-api.c:2030:bitmain_soc_init: opt_bitmain_work_mode = 0
2022-01-31 09:51:35 driver-btm-api.c:2031:bitmain_soc_init: Miner compile time: Thu Apr 23 16:29:07 CST 2020 type: Antminer T17
2022-01-31 09:51:35 driver-btm-api.c:2032:bitmain_soc_init: commit version: 1c5be6f 2020-04-20 16:18:14, build by: lol 2020-04-23 16:35:04
2022-01-31 09:51:35 driver-btm-api.c:1844:show_sn: no SN got, please write SN to /nvdata/sn
2022-01-31 09:51:35 driver-btm-api.c:1167:miner_device_init: Detect 256MB control board of XILINX
2022-01-31 09:51:35 driver-btm-api.c:1115:init_fan_parameter: fan_eft : 0 fan_pwm : 0
2022-01-31 09:51:35 thread.c:885:create_read_nonce_reg_thread: create thread
2022-01-31 09:51:41 driver-btm-api.c:1099:init_miner_version: miner ID : 80620dce57408854
2022-01-31 09:51:41 driver-btm-api.c:1105:init_miner_version: FPGA Version = 0xB013
2022-01-31 09:51:43 eeprom.c:425:check_pattern_test_level: invalid pattern test result. ignore
2022-01-31 09:51:43 driver-btm-api.c:737:get_product_id: product_id[1] = 1
2022-01-31 09:51:43 driver-btm-api.c:1666:get_ccdly_opt: ccdly_opt[1] = 1
2022-01-31 09:51:43 driver-btm-api.c:1919:bitmain_board_init: g_ccdly_opt = 1
2022-01-31 09:51:43 driver-btm-api.c:676:_set_project_type: project:2
2022-01-31 09:51:43 driver-btm-api.c:706:_set_project_type: Project type: Antminer T17
2022-01-31 09:51:43 driver-btm-api.c:717:dump_pcb_bom_version: Chain [1] PCB Version: 0x0100
2022-01-31 09:51:43 driver-btm-api.c:718:dump_pcb_bom_version: Chain [1] BOM Version: 0x0100
2022-01-31 09:51:49 driver-btm-api.c:1939:bitmain_board_init: Fan check passed.
2022-01-31 09:51:51 board.c:36:jump_and_app_check_restore_pic: chain[1] PIC jump to app
2022-01-31 09:51:55 board.c:40:jump_and_app_check_restore_pic: Check chain[1] PIC fw version=0xb9
2022-01-31 09:51:55 thread.c:880:create_pic_heart_beat_thread: create thread
2022-01-31 09:51:55 power_api.c:55
ower_init: power init ...
2022-01-31 09:51:55 driver-btm-api.c:1949:bitmain_board_init: Enter 30s sleep to make sure power release finish.
2022-01-31 09:51:55 power_api.c:46
ower_off: init gpio907
2022-01-31 09:52:27 power_api.c:232:set_iic_power_to_highest_voltage: setting to voltage: 17.00 ...
2022-01-31 09:52:28 power_api.c:124:check_voltage_multi: retry time: 0
2022-01-31 09:52:30 power_api.c:86:get_average_voltage: chain[1], voltage is: 21.185742
2022-01-31 09:52:30 power_api.c:97:get_average_voltage: aveage voltage is: 21.185742
2022-01-31 09:52:30 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.19, more than 1.0v diff.
2022-01-31 09:52:31 power_api.c:124:check_voltage_multi: retry time: 1
2022-01-31 09:52:33 power_api.c:86:get_average_voltage: chain[1], voltage is: 19.587627
2022-01-31 09:52:33 power_api.c:97:get_average_voltage: aveage voltage is: 19.587627
2022-01-31 09:52:33 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 19.59, more than 1.0v diff.
2022-01-31 09:52:34 power_api.c:124:check_voltage_multi: retry time: 2
2022-01-31 09:52:36 power_api.c:86:get_average_voltage: chain[1], voltage is: 18.430371
2022-01-31 09:52:36 power_api.c:97:get_average_voltage: aveage voltage is: 18.430371
2022-01-31 09:52:36 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 18.43, more than 1.0v diff.
2022-01-31 09:52:37 power_api.c:124:check_voltage_multi: retry time: 3
2022-01-31 09:52:39 power_api.c:86:get_average_voltage: chain[1], voltage is: 17.389453
2022-01-31 09:52:39 power_api.c:97:get_average_voltage: aveage voltage is: 17.389453
2022-01-31 09:52:39 power_api.c:182:set_iic_power_by_voltage: now set voltage to : 17.000000
2022-01-31 09:52:39 uart.c:80:set_baud: set fpga_baud = 115200, fpga_divider = 26
2022-01-31 09:52:50 driver-btm-api.c:1042:check_asic_number_with_power_on: Chain[1]: find 30 asic, times 0
2022-01-31 09:52:51 driver-btm-api.c:352:set_order_clock: chain[1]: set order clock, stragegy 3 clock_en=0x1
2022-01-31 09:52:52 driver-hash-chip.c:502:set_clock_delay_control: core_data = 0xb4
2022-01-31 09:52:52 uart.c:80:set_baud: set fpga_baud = 3000000, fpga_divider = 0
2022-01-31 09:52:52 driver-btm-api.c:1693:check_clock_counter: freq 50 clock_counter_limit 6
2022-01-31 09:52:52 uart.c:80:set_baud: set fpga_baud = 115200, fpga_divider = 26
2022-01-31 09:52:52 voltage[1] = 1710
2022-01-31 09:52:52 power_api.c:140:set_working_voltage: working_voltage = 17.100000
2022-01-31 09:52:52 temperature.c:203:is_temp_sensor_type_correct: Wrong temp sensor type, chain = 1, sensor = 8, type = 0x0, retry.
2022-01-31 09:52:53 temperature.c:203:is_temp_sensor_type_correct: Wrong temp sensor type, chain = 1, sensor = 8, type = 0x0, retry.
2022-01-31 09:52:53 driver-btm-api.c:205:set_miner_status: ERROR_TEMP_LOST_1ST
2022-01-31 09:52:53 driver-btm-api.c:159:stop_mining_and_reboot: stop mining: Re-run cgminer to check temerature sensor type again!
2022-01-31 09:52:53 thread.c:930:cancel_read_nonce_reg_thread: cancel thread
2022-01-31 09:52:53 driver-btm-api.c:131:killall_hashboard: ****power off hashboard****
2022-01-31 09:52:56 Assert fail!! driver-btm-api.c:164: reboot
