TorchSoft Registry Workshop 4.3.0.0 Full Version
[hide]این برنامه برای کسانی که با رجیستری سر و کار دارن نیازه چون می تونید کلید یا زیر کلیدی را حذف کنید ببینید که آیا واسه سیستم مشکلی پیش میاد یا نه دوباره می تونید کار انجام شدتون را براحتی و بدون ترس برگردونید
یعنی نیاز نیست که بک آپ بگیرید یا اگر کلیدی رو حذف کردید و نمی دونید چیه دوباره سیستم رو تعمیر کنید یا ویندوز را عوض کنید تا بحالت اولش برگرده
اینم توضیحات برنامه از سایت سافت پدیا
Size حجم برنامه
Mb 1/2 مگابایت
لینک دانلود مستقیم نسخه کامل Link Download Direct FullVersion
Password رمز عبور برای نصب برنامه
JAVAD-JOURSARAEI-BABOL
Registry Workshop is an advanced registry editor. It is a perfect replacement for RegEdit and RegEdt32 which shipped with Windows.
In addition to all the standard features, Registry Workshop adds a variety of powerful features that allow you to work faster and more efficiently with registry related tasks.
With Registry Workshop, registry editing becomes more safe than ever before. All changes except changing key permissions can be safely reversed (even registry replacing and importing), using multiple levels of Undo. You don't need to worry about making mistakes when editing registry.
Whether you are an advanced user who needs to edit and modify your registry to remove trojan, virus, and spyware entries, a system administrator who needs a safer, more efficient tool to maintain your company's PCs, or a software developer who needs to quickly manipulate registry keys and values during system development, Registry Workshop has the tools that you need.
You can read a review of Registry Workshop on PC Magazine's website at http://www.pcmag.com/article2/0,2817,2360098,00.asp
Key Features
Multiple undo and redo. The undo history can be saved to disk and reloaded at startup. screen shot
Search and replace registry keys, values and data with super fast search algorithm. On a typical PC, you can search the entire registry in about ten seconds! screen shot
Compare registry between computers and/or .REG files with super fast speed.
Connect mobile device (Pocket PC, SmartPhone, etc.) registry via ActiveSync.
Cut, copy and paste registry keys and values.
Drag and drop to move or copy registry keys and values.
Edit .REG files and .POL files in the same way as editing system registry. screen shot
Backup and restore registry. screen shot
Defragment registry with preview. screen shot
Easy and flexible Favorites management.
Quickly browse registry with address bar, bookmarks and visitation history.
Support of linkage aware ability. You can use context menu to navigate to referenced key, open containing folder or open URL if the key or value contains a ProgID, ClassID, folder, file path or URL.
Jump to the same key in HKLM or HKCU by context menu.
Allow to open multiple local registry windows.
Allow to open secure registry keys when running under the administrator privilege.
Edit binary data in BYTE, WORD or DWORD format.
ویندوزهای پشتیبانی شده
Windows 2000 (Service Pack 4)
Windows XP (32-bit and 64-bit)
Windows 2003 (32-bit and 64-bit)
Windows Vista (32-bit and 64-bit)
Windows 2008 (32-bit and 64-bit)
Windows 7 (32-bit and 64-bit)
محدودیت های نسخه آزمایشی این برنامه البته این نسخه کامل و بدون محدودیت می باشد
· 30 days trial period
· Added an option to disable the tooltips in Favorites window.
· Added shortcut key (Ctrl+R) to replace in find results 1.
· Fixed a bug when importing .reg files.
· Fixed a bug when open container folder with UNIX style path.
· Fixed a bug in docking framework[/hide]
با تشکر : 1389/11/30 14:53 ظهر
