توسط این نرم افزار و ترکیب چند عکس از یک صحنه کیفیت عکس خود چند برابر کنید
6,774
29,828
Almalence PhotoAcute v3.50 S60v3 Symbian9.x Keygen BiNPDAاین
نرم افزار به شما کمک میکنه که با گرفتند چندین عکس پشت سر هم از یک صحنه و ترکیب آنها کیفیت عکس خود را چند برابر کنید
PhotoAcute Mobile application makes it possible to take high-quality and low-noise pictures with your camera phone, as if it had a larger matrix and better lens.
By applying state-of-the-art image processing techniques, PhotoAcute allows the user to achieve up to 2-times increase in resolution.
PhotoAcute Example
PhotoAcute Mobile features:
* Increased image resolution
* Pictures with fine details that are usually invisible/indistinguishable
* Image noise reduction
* Geometry correction
* Interlacing artefacts removal
* Improving brighteness at the edges of picture
The resolution of mobile phone cameras is relatively low. Nowadays they usually have 1-2 megapixels, while generic digital cameras resolution starts from 3 megapixels.
Size matters, details make the difference
PhotoAcute Mobile produces 2-times larger photographs (for example, 2400x1800 instead of 1600x1200 for Nokia N90). Unlike the digital zooming and image sharpening, resultant photographs produced by PhotoAcute Mobile do really have higher spatial resolution. Small, thin and far away objects, textures and inscriptions become recognizable.
How does it work?
PhotoAcute Mobile processes several photographs taken in sequence mode, thus acquiring more graphic information than is available from a single photograph. Using sophisticated proprietary algorithms it combines the individual images to produce one large-sized and high-quality image. It also performs additional image processing to make the resultant picture sharper and remove defects. Using the state-of-art algorithms allows it to achieve a great increase in quality.
PhotoAcute Mobile performs all image processing on the handset, so you do not need to use any desktop computer.
Note :this is new update on 7.8.2008
از اینجا دانلود کنید
