کنترل کامل گوشی از قبیل میزان باتری و انرژی تماس ها و اس ام اس های از دست رفته و ...
نیاز به ساین دارد.
نقل قول از شایان :
نقل قول:
نرم افزار کاربردی دیگری که ...
زمانی که باتری به حد مورد نظر شما رسید، بوق مورد نظر شما رو میزنه.
زمانی که SMS جدید دریافت کردید، به شما هشدار میده.
زمانی که Missed Call دارید، به شما هشدار میده .
قابلیت تنظیم فاصله ی زمانی و زنگ هشدار رو هم داره و در startup هم قرار میگیره.
A program for all reminders of missed events. Released for Symbian 9.2.
In the first version has reminders of missed calls, SMS and low battery power. Personally, I these napominalok enough. But I shall consider your wishes for adding new napominalok. Benefit application architecture originally designed for the possibility of adding new napominalok.
If we missed events program begins to file periodic signals. For each type of missed events can customize your message.
An audible signal silence can be pressing any key.
Where is this key look in the manual to your phone
Loudness alarm and mode of operation vibrosignala (working or not) is taken from the current profile. If your phone to silent night shifts or in quiet mode, the program, respectively, will not lodge signals, or will do so quietly.
In the distribution included two signals, which are used by default. It turns out not all phones have signals that I used earlier.
General settings. So far only autoload. In accordance with the accepted practice of programming, is off by default autoload
To move to other settings, press right into the joystick.
Notification of missed calls.
If there is a missed call and the program sends signals, then set "check" to 'no', you can stop the transmission of signals about missed calls.
Alert on unread SMS.
If there is unread SMS and the program sends signals, then set "check" to 'no', you can stop the transmission of signals of unread SMS.
Alert the low battery charge.
If the charge is equal to or below a given, then begins to give the signals.
If the phone rechargeable, the signals are not filed
It is not advisable to appoint a second concert of Rachmaninoff as a warning to the melody, otherwise you risk not hear the end of the work
New functionality added
Fix
If you reject an incoming call, the program felt it missed and began to give the signals.
If playing the melody to suspend multiple keystroke, the next play, too, will be interrupted, as if the user presses the button.
Fixed title buttons. Change "Save settings" to "Finish" in the Russian version, "Save settings" to "OK" and "Edit Text" to "Off", the English version
نیاز به ساین دارد.
نقل قول از شایان :
نقل قول:
![clear.gif](https://www.irantk.ir/clear.gif)
Fix
115.9 کیلوبایت بازدیدها: 33
