t17
h_sarghani
239
40
34
مشهد
فریمور از کجا گیر بیارم که به دما گیر نده واتس اپ دارین استاد گرامی
h_sarghani
239
40
34
مشهد
با خود کابل دیتا هشتبرد درست کردم با nm5000 رید میگیرم کپی حذف همه کتر میکنم نیازی به کد ادیتور نیست
h_sarghani
239
40
34
مشهد
fpga mem virtual address is 0xd2000000
2022-01-31 09:51:35 driver-btm-api.c:663:init_freq_mode: This is scan-user version
2022-01-31 09:51:35 driver-btm-api.c:2028:bitmain_soc_init: opt_multi_version = 1
2022-01-31 09:51:35 driver-btm-api.c:2029:bitmain_soc_init: opt_bitmain_ab = 1
2022-01-31 09:51:35 driver-btm-api.c:2030:bitmain_soc_init: opt_bitmain_work_mode = 0
2022-01-31 09:51:35 driver-btm-api.c:2031:bitmain_soc_init: Miner compile time: Thu Apr 23 16:29:07 CST 2020 type: Antminer T17
2022-01-31 09:51:35 driver-btm-api.c:2032:bitmain_soc_init: commit version: 1c5be6f 2020-04-20 16:18:14, build by: lol 2020-04-23 16:35:04
2022-01-31 09:51:35 driver-btm-api.c:1844:show_sn: no SN got, please write SN to /nvdata/sn
2022-01-31 09:51:35 driver-btm-api.c:1167:miner_device_init: Detect 256MB control board of XILINX
2022-01-31 09:51:35 driver-btm-api.c:1115:init_fan_parameter: fan_eft : 0 fan_pwm : 0
2022-01-31 09:51:35 thread.c:885:create_read_nonce_reg_thread: create thread
2022-01-31 09:51:41 driver-btm-api.c:1099:init_miner_version: miner ID : 80620dce57408854
2022-01-31 09:51:41 driver-btm-api.c:1105:init_miner_version: FPGA Version = 0xB013
2022-01-31 09:51:43 eeprom.c:425:check_pattern_test_level: invalid pattern test result. ignore
2022-01-31 09:51:43 driver-btm-api.c:737:get_product_id: product_id[1] = 1
2022-01-31 09:51:43 driver-btm-api.c:1666:get_ccdly_opt: ccdly_opt[1] = 1
2022-01-31 09:51:43 driver-btm-api.c:1919:bitmain_board_init: g_ccdly_opt = 1
2022-01-31 09:51:43 driver-btm-api.c:676:_set_project_type: project:2
2022-01-31 09:51:43 driver-btm-api.c:706:_set_project_type: Project type: Antminer T17
2022-01-31 09:51:43 driver-btm-api.c:717:dump_pcb_bom_version: Chain [1] PCB Version: 0x0100
2022-01-31 09:51:43 driver-btm-api.c:718:dump_pcb_bom_version: Chain [1] BOM Version: 0x0100
2022-01-31 09:51:49 driver-btm-api.c:1939:bitmain_board_init: Fan check passed.
2022-01-31 09:51:51 board.c:36:jump_and_app_check_restore_pic: chain[1] PIC jump to app
2022-01-31 09:51:55 board.c:40:jump_and_app_check_restore_pic: Check chain[1] PIC fw version=0xb9
2022-01-31 09:51:55 thread.c:880:create_pic_heart_beat_thread: create thread
2022-01-31 09:51:55 power_api.c:55:power_init: power init ...
2022-01-31 09:51:55 driver-btm-api.c:1949:bitmain_board_init: Enter 30s sleep to make sure power release finish.
2022-01-31 09:51:55 power_api.c:46:power_off: init gpio907
2022-01-31 09:52:27 power_api.c:232:set_iic_power_to_highest_voltage: setting to voltage: 17.00 ...
2022-01-31 09:52:28 power_api.c:124:check_voltage_multi: retry time: 0
2022-01-31 09:52:30 power_api.c:86:get_average_voltage: chain[1], voltage is: 21.185742
2022-01-31 09:52:30 power_api.c:97:get_average_voltage: aveage voltage is: 21.185742
2022-01-31 09:52:30 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 21.19, more than 1.0v diff.
2022-01-31 09:52:31 power_api.c:124:check_voltage_multi: retry time: 1
2022-01-31 09:52:33 power_api.c:86:get_average_voltage: chain[1], voltage is: 19.587627
2022-01-31 09:52:33 power_api.c:97:get_average_voltage: aveage voltage is: 19.587627
2022-01-31 09:52:33 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 19.59, more than 1.0v diff.
2022-01-31 09:52:34 power_api.c:124:check_voltage_multi: retry time: 2
2022-01-31 09:52:36 power_api.c:86:get_average_voltage: chain[1], voltage is: 18.430371
2022-01-31 09:52:36 power_api.c:97:get_average_voltage: aveage voltage is: 18.430371
2022-01-31 09:52:36 power_api.c:110:check_voltage: target_vol = 17.00, actural_vol = 18.43, more than 1.0v diff.
2022-01-31 09:52:37 power_api.c:124:check_voltage_multi: retry time: 3
2022-01-31 09:52:39 power_api.c:86:get_average_voltage: chain[1], voltage is: 17.389453
2022-01-31 09:52:39 power_api.c:97:get_average_voltage: aveage voltage is: 17.389453
2022-01-31 09:52:39 power_api.c:182:set_iic_power_by_voltage: now set voltage to : 17.000000
2022-01-31 09:52:39 uart.c:80:set_baud: set fpga_baud = 115200, fpga_divider = 26
2022-01-31 09:52:50 driver-btm-api.c:1042:check_asic_number_with_power_on: Chain[1]: find 30 asic, times 0
2022-01-31 09:52:51 driver-btm-api.c:352:set_order_clock: chain[1]: set order clock, stragegy 3 clock_en=0x1
2022-01-31 09:52:52 driver-hash-chip.c:502:set_clock_delay_control: core_data = 0xb4
2022-01-31 09:52:52 uart.c:80:set_baud: set fpga_baud = 3000000, fpga_divider = 0
2022-01-31 09:52:52 driver-btm-api.c:1693:check_clock_counter: freq 50 clock_counter_limit 6
2022-01-31 09:52:52 uart.c:80:set_baud: set fpga_baud = 115200, fpga_divider = 26
2022-01-31 09:52:52 voltage[1] = 1710
2022-01-31 09:52:52 power_api.c:140:set_working_voltage: working_voltage = 17.100000
2022-01-31 09:52:52 temperature.c:203:is_temp_sensor_type_correct: Wrong temp sensor type, chain = 1, sensor = 8, type = 0x0, retry.
2022-01-31 09:52:53 temperature.c:203:is_temp_sensor_type_correct: Wrong temp sensor type, chain = 1, sensor = 8, type = 0x0, retry.
2022-01-31 09:52:53 driver-btm-api.c:205:set_miner_status: ERROR_TEMP_LOST_1ST
2022-01-31 09:52:53 driver-btm-api.c:159:stop_mining_and_reboot: stop mining: Re-run cgminer to check temerature sensor type again!
2022-01-31 09:52:53 thread.c:930:cancel_read_nonce_reg_thread: cancel thread
2022-01-31 09:52:53 driver-btm-api.c:131:killall_hashboard: ****power off hashboard****
2022-01-31 09:52:56 Assert fail!! driver-btm-api.c:164: reboot
h_sarghani
239
40
34
مشهد
سنسور 8 دقیقا کجارو میگه منظورش چیپ شماره 8 هست
milani1387
65
12
دوست من من موقع تست هشبرد سری 17 با 4 تا فن روی میز 2 تا زیر دوتا روش به زور خنکش می کنم
شما چه جور با تک فن خنکش می کنید؟؟؟
ببینید به احساس دمای دست شما نیست شاید دست شما بیش از 70 درجه حس نکنه ولی دمای داخلی تا 300 هم بره...
دست من هشبرد ترکید و دیدم..
milani1387
65
12
کلا
اکثرا
هشبردهای سری بیت مین اگر ایراد دما گرفت در اکثر موارد لحیم سری چیپ و خرابی هست و ربطی سنسور دما نداره..
milani1387
65
12
فریمور کاستوم بهشون میگن..
فرق بین فریمور کاستوم و شرکتی در اینه که اطلاعات داخل میکرو نظیر فرکانسها را نادیده میگیره وتنظیمات داخلی فریمور را اعمال می کنه...
اگر ایراد سخت افزاری داشته باشی فریمور چه شرکتی چه کاستوم هیچ اثری در کارکرد نداره....
برای سری 17 توصیه من استفاده از فریمور خود بیت مین هست....
milani1387
65
12
من هرچی گشتم تو اینترنت چیزی پیدا نکردم راجب این مشکل فقط شنیدم فریمور هایی هست که رو کنترل برد نصب میشه دما رو دور میزنه و ماین میکنه
Nimashafaati
6
هر چهار سنسور هر کدوم دو تا پایه خروجی temp n و temp p دارن که میخوره به چهار تا اسیک که هر سنسور به یک اسیک متصل هست با ریزولد این چهار اسیک به احتمال زیاد مشکل حل میشه
