مشکل: تعمیر بوت ویندوز 7
pese
257
1,549
www.servicekaran.ir
[h=2]SFC /SCANNOW : Run in Command Prompt at Boot[/h]
Method One
For Windows 7 and Vista full version installation media, after the "Press any key ... " black screen do steps #1 & #2 then skip down to step #5 below to continue.
For a Windows system repair disk start at step #3 below.
1) At the Select Language screen click next.
click any image to enlarge
2) At the next screen click Repair your Computer.
3) For a Windows created repair CD, after the "Press any key ... " black screen there will be a Loading Files screen.
4) Then click Next for this System Recovery Options dialog box.
5) At this System Recovery Options dialog box, make sure there is a dot at "Use Recovery Tools" and be sure to make note of the Location drive letter as it probably will not be C: and the correct drive letter must be entered in the following steps; then click Next.
6) At this System Recovery Options dialog box click Command Prompt.
7) In the command window that opens type this command below and hit the <enter> key, be sure to use your drive letter, where mine is F: for this demonstration yours probably will not be the same.
Code:
sfc /scannow /offbootdir=f:\ /offwindir=f:\windows
8) You will get a blinking curser while it checks and attempts to repair any issues it may find, it could take quite a bit of time to complete.
9) To close the command window after the scan type exit and hit the <enter> key.
Though my demonstration / test found no errors to repair, yours may and if it does it may take you running this command a couple separate times to completely repair any issues it finds so don't give up after just one attempt.
For further important information on this process, see Option Two of this tutorial at the link below.
SFC /SCANNOW Command - System File Checker
10) To restart the PC when the command window closes, remove the Windows / repair disk from the ODD and click Restart in the System Recovery Options dialog box that's still open.
Method Two
It has been suggested by Brink to include this method for those dual/multi booting and for those that have issues with WinRE 'seeing' the Windows Operating System partition needing repair.
In the BIOS set the boot order to boot first from the CD/DVD Drive, insert the Windows full version installation DVD or a created repair CD and restart the PC so diskpart can be started, if need be, view this tutorial for those methods.
How to Boot to DISKPART at PC Startup
1) In the diskpart command window type list volume and hit the <enter> key.
2) After it lists the volumes type exit a single time and <enter>.
ckick to enlarge
3) Now type the command below using your specific volume drive letters <enter>.
If you are dual/multi booting or have a System Reserved partition as I do and the system boot files are stored on a separate partition than the Operating System partition needing repair, in any case, the volume drive letter where the system boot files are stored goes in the first part.
offbootdir=c:
In the second part you would use the volume drive letter for the Windows OS partition you want to attempt the repair on.
offwindir=f:
Code:
sfc /scannow /offbootdir=c:\ /offwindir=f:\windows
4) You will get a blinking curser while it checks and attempts to repair any issues it may find, it could take quite a bit of time to complete.
5) Though my demonstration / test found no errors to repair, yours may and if it does it may take you running this command a couple separate times to completely repair any issues it finds so don't give up after just one attempt.
6) To close the command window after the scan type exit and hit the <enter> key.
Then remove the Windows disk from the ODD and restart the PC to start Windows.
Enjoy
maryam_sh
431
234
واسه اون قسمتی که با عکس مشخص کردم چطور برسی کنم؟
واکنش‌ها[ی پسندها]: 1212ali
maryam_sh
431
234
وقتی ویندوز بالا نمیاد بنده چطور Command promptرا بعنوان administratorاجرا کنم؟؟؟؟؟
yaghob20
600
2,865
سلام دوستان یه لپ تاپ با ویندوز 7 واسم آوردن ویندوز بالا نمیاد و موقعی که روشن میکنم مستقیم میره صفحه تsystem recovery ophtiones و بنده اقدم به تعمیر هم میکنم ولی باز هم درست نمیشه.مشتری نمیخواد ویندوز از نو نصب کنه و میخواد این ویندوز تعمیرش بشه به کمک شما دوستان نیاز دارم که ویندوز رو تعمیر کنم.
درضمن موقعی میخواد وارد صفحه system recovery بشه این ارور میده کهعکسش ضمیمه کردم
همکار عزیر درایو c شما به احتمال زیاد از حالت active بودن خارج شده
شما باید یا تجت بوت هایرن دوباره active کنید یا اینکه هارد رو سیستم دیگه بیارید بالا و با نرم افزار تحت ویندوز active کنید
maryam_sh
431
234
منظور از active چیه؟با کدوم نرم افزار باید اینکار رو انجام داد؟میشه بیشتر توضیح بدین؟
yaghob20
600
2,865
هارد رو به عنوان هارد دوم به سیستم معرفی کن
یه تصویر از disk management بزار
maryam_sh
431
234
همکار عزیز جواب سوال بنده رو ندادین.منظور از active چیه و با کدوم نرم افزار باید این کار رو انجام بدم؟
درضمن اگه بنده بخوام هارد رو از روی لپ تاپ باز کنم لپ تاپ از گارانتی سخت افزار خارج میشه
imanfc
345
1,003
دوست عزیز اگر مشکل شما سخت افزاری نیست و هاردتون بد سکتور نداره مشتری چرا اصرار داره ویندوز عوض نکنی ؟
اگر اطلاعات داره شما سیستم رو با نرم افزار Live Boot بالا بیار هر کار نرم افزاری که دوستان فرمودن انجام بده اگر به نتیجه رسیدی که هیچ اگرم به نتیجه نرسیدی اطلاعات مهمش رو انتقال بده به یه درایور و نصب ویندوز کن
maryam_sh
431
234
به خاطر یه سری از نرم افزار های تخصصی که روی سیستم نصب کردن مشتری نمیخواد ویندوز از نو نصب کنه به این دلیل هست
