نرم افزارهاي فرمت و احياي کول ديسک هاي LG
Service Manual
D e b u g g e R
13,680
176,837
iRanTK.iR
کد:
[LEFT][B][FONT="Tahoma"][SIZE="2"][COLOR="#0000ff"][INDENT][LTR]
Utilities and drivers for LG USB Flash Drives
Branded utility for low-level format and restore flash controllers OTI.
Supported controllers: 2167, 2166, 2169M, 2165, 2168, 2168B5, 2169SB5, 2189SB3, 2168B6, 2168SB6, 6828, 6128 and others.
Such controllers are usually in a flash drive and LG KingMax. There may be other manufacturers.
We see that in your flash drive is the controller OTI.
Install the program, connect the USB flash drive. If not specified, go to the menu Driver> Reinstall. If it is determined you will see options to flash and it will have the status "Waiting". Then go to the Tools menu and select the menu settings of your controller. After all the manipulations select the line with the flash and press Enter. Settings sohranyattsya the controller, if there is no write errors, status changes to "Pass".
Note: After repair flash drive these tools, the data will not be able to recover
[/LTR][/INDENT][/COLOR][/SIZE][/FONT][/B][/LEFT]
