مشکل: باز نشدن هارد اکسترنال بر روی مک بوک پرو 13 اینچی . (اصن نمیشناسه!!)
c3ntoo
دوستان از دیجی کالا هارد وسترن گرفتم 2 ترا.
ولی وصل ک میکنم ب مک نمیشناسه فایل های نصبی
40,210
این مراحلش هست
[h=2]Format in OS X[/h]
[h=4]Step 1[/h] Connect the Western Digital My Passport drive to a USB port on the Mac computer, and wait for a few seconds for OS X to detect and mount the drive for use. After OS X mounts the drive, a new hard drive icon appears on the desktop.
[h=4]Step 2[/h] Click Finder on the OS X Dock. After the Finder window opens, click "Go" on the menu bar and then "Utilities" to open the /Applications/Utilities folder in Finder.
[h=4]Step 3[/h] Click the "Disk Utility" link in the Utilities folder window. After the Disk Utility application opens, click the icon for the My Passport drive in the sidebar.
[h=4]Step 4[/h] Click "Erase" on the Disk Utility file menu. After the Erase dialogue window appears, click the "Volume Format" drop-down list and select "MS-DOS File System."
[h=4]Step 5[/h] Click the "Security Options" button, then select the "Zero Out Data" option in the Secure Erase Options window and click "OK."
[h=4]Step 6[/h] Click the "Erase" button and wait a few minutes for OS X to erase data on the drive and reformat it using the FAT32 format.
[h=4]Step 7[/h] Use the drive in OS X as you normally would.
c3ntoo
متشکم دمت ام گرم ! مشکلم حلید ! 3>
واکنش‌ها[ی پسندها]: AMD
