مفهوم اختصارات كاربردي در الكترونيك { فرهنگ الكترونيك }
5,023
106,544
{ Abbreviations used in Electronics }
در علم الكترونيك با حروفات مختصري مواجه ميشويد كه معني و مفهوم ان را نميدانيد !!!! بسيار خوب اين حروف با انتخاب اولين حرف از چند كلمه اي كه يك جمله معني داري تشكيل شده است در اصطلاح {ابرويشن } ناميده ميشوند :
در اين تاپيك با تعدادي از اين اختصارات و مفهوم انها بيشتر اشنا ميشويد :
N to TWT
N[FONT=&quot] [/FONT]
Number of turns in an inductor[FONT=&quot] [/FONT]
Revolutions per minute[FONT=&quot] [/FONT]
n[FONT=&quot] [/FONT]
Nano (10-9)[FONT=&quot] [/FONT]
Negative[FONT=&quot] [/FONT]
nA[FONT=&quot] [/FONT]
Nanoampere[FONT=&quot] [/FONT]
NC[FONT=&quot] [/FONT]
Normally closed[FONT=&quot] [/FONT]
No connection[FONT=&quot] [/FONT]
NEG, neg[FONT=&quot] [/FONT]
nF[FONT=&quot] [/FONT]
Nanofarad[FONT=&quot] [/FONT]
nH[FONT=&quot] [/FONT]
Nanohenry[FONT=&quot] [/FONT]
nm[FONT=&quot] [/FONT]
Nanometer[FONT=&quot] [/FONT]
NO[FONT=&quot] [/FONT]
Normally open[FONT=&quot] [/FONT]
NPN[FONT=&quot] [/FONT]
Negative-positive-negative[FONT=&quot] [/FONT]
ns[FONT=&quot] [/FONT]
Nanosecond[FONT=&quot] [/FONT]
nW[FONT=&quot] [/FONT]
Nanowatt[FONT=&quot] [/FONT]
OP AMP[FONT=&quot] [/FONT]
Operational amplifier[FONT=&quot] [/FONT]
Pico (10-12)[FONT=&quot] [/FONT]
Power[FONT=&quot] [/FONT]
p[FONT=&quot] [/FONT]
Instantaneous power[FONT=&quot] [/FONT]
Positive, also peak[FONT=&quot] [/FONT]
PA[FONT=&quot] [/FONT]
Public address or power amplifier[FONT=&quot] [/FONT]
pA[FONT=&quot] [/FONT]
Picoampere[FONT=&quot] [/FONT]
PAL[FONT=&quot] [/FONT]
Programmable Array Logic[FONT=&quot] [/FONT]
PAM, pam[FONT=&quot] [/FONT]
Pulse amplitude modulation[FONT=&quot] [/FONT]
Pap[FONT=&quot] [/FONT]
Apparent power[FONT=&quot] [/FONT]
Pav[FONT=&quot] [/FONT]
Average power[FONT=&quot] [/FONT]
PCB[FONT=&quot] [/FONT]
Printed circuit board[FONT=&quot] [/FONT]
PCM, pcm[FONT=&quot] [/FONT]
Pulse-code modulation[FONT=&quot] [/FONT]
PDM[FONT=&quot] [/FONT]
Pulse-duration modulation[FONT=&quot] [/FONT]
pF[FONT=&quot] [/FONT]
Picofarad[FONT=&quot] [/FONT]
PLD[FONT=&quot] [/FONT]
Programmable Logic Device[FONT=&quot] [/FONT]
PLL[FONT=&quot] [/FONT]
Phase locked loop[FONT=&quot] [/FONT]
PM[FONT=&quot] [/FONT]
Phase modulation, also Permanent magnet[FONT=&quot] [/FONT]
PNP[FONT=&quot] [/FONT]
Positive-negative-positive[FONT=&quot] [/FONT]
POT, pot[FONT=&quot] [/FONT]
Potentiometer[FONT=&quot] [/FONT]
P-P[FONT=&quot] [/FONT]
Peak to peak[FONT=&quot] [/FONT]
PPM[FONT=&quot] [/FONT]
Pulse-position modulation[FONT=&quot] [/FONT]
PRF[FONT=&quot] [/FONT]
Pulse repetition frequency[FONT=&quot] [/FONT]
PRT[FONT=&quot] [/FONT]
Pulse repetition time[FONT=&quot] [/FONT]
pw[FONT=&quot] [/FONT]
Pulse width[FONT=&quot] [/FONT]
PWM, pwm[FONT=&quot] [/FONT]
Pulse width modulation[FONT=&quot] [/FONT]
Q[FONT=&quot] [/FONT]
Charge, also quality[FONT=&quot] [/FONT]
q[FONT=&quot] [/FONT]
Instantaneous charge[FONT=&quot] [/FONT]
R[FONT=&quot] [/FONT]
Resistance[FONT=&quot] [/FONT]
RAM[FONT=&quot] [/FONT]
Random access memory[FONT=&quot] [/FONT]
RC[FONT=&quot] [/FONT]
Resistance-capacitance, also Radio controlled[FONT=&quot] [/FONT]
rcvr[FONT=&quot] [/FONT]
Receiver[FONT=&quot] [/FONT]
rect[FONT=&quot] [/FONT]
Rectifier[FONT=&quot] [/FONT]
ref[FONT=&quot] [/FONT]
Reference[FONT=&quot] [/FONT]
rf[FONT=&quot] [/FONT]
Radio frequencies[FONT=&quot] [/FONT]
RFI[FONT=&quot] [/FONT]
Radio frequency interference[FONT=&quot] [/FONT]
RL[FONT=&quot] [/FONT]
Load resistor[FONT=&quot] [/FONT]
RLC[FONT=&quot] [/FONT]
Resistance-capacitance-inductance[FONT=&quot] [/FONT]
RMS, rms[FONT=&quot] [/FONT]
Root mean square[FONT=&quot] [/FONT]
ROM[FONT=&quot] [/FONT]
Read only memory[FONT=&quot] [/FONT]
rpm[FONT=&quot] [/FONT]
SCR[FONT=&quot] [/FONT]
Silicon controlled rectifier[FONT=&quot] [/FONT]
SHF[FONT=&quot] [/FONT]
Super high frequency[FONT=&quot] [/FONT]
SIP[FONT=&quot] [/FONT]
Single in-line package[FONT=&quot] [/FONT]
SNR[FONT=&quot] [/FONT]
Signal-to-noise ratio[FONT=&quot] [/FONT]
SPDT[FONT=&quot] [/FONT]
Single pole double throw[FONT=&quot] [/FONT]
sq cm[FONT=&quot] [/FONT]
Square centimeter[FONT=&quot] [/FONT]
SSB[FONT=&quot] [/FONT]
Single sideband[FONT=&quot] [/FONT]
SW[FONT=&quot] [/FONT]
Short wave[FONT=&quot] [/FONT]
SWR[FONT=&quot] [/FONT]
Standing-wave ratio[FONT=&quot] [/FONT]
SYNC, sync[FONT=&quot] [/FONT]
Synchronous[FONT=&quot] [/FONT]
Tera (1012)[FONT=&quot] [/FONT]
Torque[FONT=&quot] [/FONT]
Transformer[FONT=&quot] [/FONT]
Time in seconds[FONT=&quot] [/FONT]
TC[FONT=&quot] [/FONT]
Time constant, also temperature coefficient[FONT=&quot] [/FONT]
TE[FONT=&quot] [/FONT]
Transverse electric[FONT=&quot] [/FONT]
temp[FONT=&quot] [/FONT]
Temperature[FONT=&quot] [/FONT]
THz[FONT=&quot] [/FONT]
Terahertz[FONT=&quot] [/FONT]
TM[FONT=&quot] [/FONT]
Transverse magnetic[FONT=&quot] [/FONT]
TR[FONT=&quot] [/FONT]
Transmit-receive[FONT=&quot] [/FONT]
TTL[FONT=&quot] [/FONT]
Transistor-transistor logic[FONT=&quot] [/FONT]
TV[FONT=&quot] [/FONT]
Television[FONT=&quot] [/FONT]
TWT[FONT=&quot] [/FONT]
Travelling wave tube[FONT=&quot] [/FONT]
UHF[FONT=&quot] [/FONT]
Ultra high frequency[FONT=&quot] [/FONT]
UHV[FONT=&quot] [/FONT]
Ultra high voltage[FONT=&quot] [/FONT]
UJT[FONT=&quot] [/FONT]
Unijunction transistor[FONT=&quot] [/FONT]
UV[FONT=&quot] [/FONT]
Ultraviolet[FONT=&quot] [/FONT]
Vacuum tube[FONT=&quot] [/FONT]
V, v[FONT=&quot] [/FONT]
Volt[FONT=&quot] [/FONT]
Instantaneous voltage[FONT=&quot] [/FONT]
VA[FONT=&quot] [/FONT]
Volt ampere[FONT=&quot] [/FONT]
Vav[FONT=&quot] [/FONT]
Voltage (average value)[FONT=&quot] [/FONT]
VBE[FONT=&quot] [/FONT]
DC voltage base to emitter[FONT=&quot] [/FONT]
Vc[FONT=&quot] [/FONT]
Capacitive voltage[FONT=&quot] [/FONT]
VCE[FONT=&quot] [/FONT]
DC voltage collector to emitter[FONT=&quot] [/FONT]
VCO[FONT=&quot] [/FONT]
Voltage controlled oscillator[FONT=&quot] [/FONT]
VHF[FONT=&quot] [/FONT]
Very high frequency[FONT=&quot] [/FONT]
Vin[FONT=&quot] [/FONT]
Input voltage[FONT=&quot] [/FONT]
VL[FONT=&quot] [/FONT]
Inductive voltage[FONT=&quot] [/FONT]
VLF[FONT=&quot] [/FONT]
Very low frequency[FONT=&quot] [/FONT]
Vm, Vmax[FONT=&quot] [/FONT]
Maximum voltage[FONT=&quot] [/FONT]
VOM[FONT=&quot] [/FONT]
Volt ohm milliameter[FONT=&quot] [/FONT]
Vout[FONT=&quot] [/FONT]
Output voltage[FONT=&quot] [/FONT]
Vp[FONT=&quot] [/FONT]
Primary voltage[FONT=&quot] [/FONT]
VS[FONT=&quot] [/FONT]
Source voltage[FONT=&quot] [/FONT]
VSWR[FONT=&quot] [/FONT]
Voltage standing wave ratio[FONT=&quot] [/FONT]
VT[FONT=&quot] [/FONT]
Total voltage[FONT=&quot] [/FONT]
Watt[FONT=&quot] [/FONT]
XC[FONT=&quot] [/FONT]
Capacitive reactance[FONT=&quot] [/FONT]
XL[FONT=&quot] [/FONT]
Inductive reactance[FONT=&quot] [/FONT]
Y[FONT=&quot] [/FONT]
Admittance[FONT=&quot] [/FONT]
Z[FONT=&quot] [/FONT]
Impedance[FONT=&quot] [/FONT]
Zin[FONT=&quot] [/FONT]
Input impedance[FONT=&quot] [/FONT]
Zo[FONT=&quot] [/FONT]
Output impedance[FONT=&quot] [/FONT]
Zp[FONT=&quot] [/FONT]
Primary impedance[FONT=&quot] [/FONT]
Zs[FONT=&quot] [/FONT]
Secondary impedance[FONT=&quot] [/FONT]
ZT[FONT=&quot] [/FONT]
Total impedance[FONT=&quot] [/FONT]
ادامه دارد :
با تشكر .
موفق باشيد
5,023
106,544
قسمت دوم :
A to mW
A (amp)[FONT=&quot] [/FONT]
Ampere[FONT=&quot] [/FONT]
AC[FONT=&quot] [/FONT]
Alternating current[FONT=&quot] [/FONT]
AC/DC[FONT=&quot] [/FONT]
Alternating current or direct current[FONT=&quot] [/FONT]
A/D[FONT=&quot] [/FONT]
Analog to digital[FONT=&quot] [/FONT]
ADC[FONT=&quot] [/FONT]
Analog-to-digital converter[FONT=&quot] [/FONT]
AF[FONT=&quot] [/FONT]
Audio frequency[FONT=&quot] [/FONT]
AFT[FONT=&quot] [/FONT]
Automatic fine tunung[FONT=&quot] [/FONT]
AFC[FONT=&quot] [/FONT]
Automatic frequency control[FONT=&quot] [/FONT]
Automatic flow controller, used in controlling the flow of gasses under pressure into a vacuum system[FONT=&quot] [/FONT]
AGC[FONT=&quot] [/FONT]
Automatic gain control[FONT=&quot] [/FONT]
Ah[FONT=&quot] [/FONT]
Ampere hour[FONT=&quot] [/FONT]
Ai[FONT=&quot] [/FONT]
Current gain[FONT=&quot] [/FONT]
Amplitude modulation[FONT=&quot] [/FONT]
AM/FM[FONT=&quot] [/FONT]
Amplitude modulation or Frequency modulation[FONT=&quot] [/FONT]
AMM[FONT=&quot] [/FONT]
Analog multimeter[FONT=&quot] [/FONT]
antilog[FONT=&quot] [/FONT]
Antilogarithm[FONT=&quot] [/FONT]
Ap[FONT=&quot] [/FONT]
Power gain[FONT=&quot] [/FONT]
apc[FONT=&quot] [/FONT]
Automatic phase control[FONT=&quot] [/FONT]
Av[FONT=&quot] [/FONT]
Voltage gain[FONT=&quot] [/FONT]
AVC[FONT=&quot] [/FONT]
Automatic volume control[FONT=&quot] [/FONT]
AWG[FONT=&quot] [/FONT]
American wire gauge[FONT=&quot] [/FONT]
Flux density[FONT=&quot] [/FONT]
BCD[FONT=&quot] [/FONT]
Binary coded decimal[FONT=&quot] [/FONT]
bfo[FONT=&quot] [/FONT]
Beat frequency oscillator[FONT=&quot] [/FONT]
BJT[FONT=&quot] [/FONT]
Bipolar junction transistor[FONT=&quot] [/FONT]
BW[FONT=&quot] [/FONT]
Bandwidth[FONT=&quot] [/FONT]
Centi (10-2)[FONT=&quot] [/FONT]
Capacitance or capacitor[FONT=&quot] [/FONT]
CAD[FONT=&quot] [/FONT]
Computer aided design[FONT=&quot] [/FONT]
CAM[FONT=&quot] [/FONT]
Computer aided manufacture[FONT=&quot] [/FONT]
CATV[FONT=&quot] [/FONT]
Cable TV[FONT=&quot] [/FONT]
Common base configuration[FONT=&quot] [/FONT]
Citizen's band[FONT=&quot] [/FONT]
CC[FONT=&quot] [/FONT]
Common collector[FONT=&quot] [/FONT]
Common emitter[FONT=&quot] [/FONT]
Centimeter[FONT=&quot] [/FONT]
cmil[FONT=&quot] [/FONT]
Circular mil[FONT=&quot] [/FONT]
CPU[FONT=&quot] [/FONT]
Central processing unit[FONT=&quot] [/FONT]
C (Q)[FONT=&quot] [/FONT]
Coulomb[FONT=&quot] [/FONT]
CR cr[FONT=&quot] [/FONT]
Junction diode[FONT=&quot] [/FONT]
CRO[FONT=&quot] [/FONT]
Cathode ray oscilloscope[FONT=&quot] [/FONT]
CRT[FONT=&quot] [/FONT]
Cathode ray tube[FONT=&quot] [/FONT]
CT[FONT=&quot] [/FONT]
Total capacitance[FONT=&quot] [/FONT]
cw[FONT=&quot] [/FONT]
Continuous transmission[FONT=&quot] [/FONT]
Deci (10-1)[FONT=&quot] [/FONT]
D/A or D-A[FONT=&quot] [/FONT]
Digital to analog[FONT=&quot] [/FONT]
Direct current[FONT=&quot] [/FONT]
Di or Di[FONT=&quot] [/FONT]
Change in current[FONT=&quot] [/FONT]
DIP[FONT=&quot] [/FONT]
Dual in-line package[FONT=&quot] [/FONT]
DMM[FONT=&quot] [/FONT]
Digital multimeter[FONT=&quot] [/FONT]
DPDT[FONT=&quot] [/FONT]
Double pole double throw[FONT=&quot] [/FONT]
Dt or Dt[FONT=&quot] [/FONT]
Change in time[FONT=&quot] [/FONT]
DTL[FONT=&quot] [/FONT]
Diode transistor logic[FONT=&quot] [/FONT]
Dv or Dv[FONT=&quot] [/FONT]
Change in voltage[FONT=&quot] [/FONT]
DVM[FONT=&quot] [/FONT]
Digital voltmeter[FONT=&quot] [/FONT]
E DC or Erms[FONT=&quot] [/FONT]
Difference in potential[FONT=&quot] [/FONT]
Instantaneous difference in potential[FONT=&quot] [/FONT]
ECG[FONT=&quot] [/FONT]
Electrocardiogram[FONT=&quot] [/FONT]
ECL[FONT=&quot] [/FONT]
Emitter coupled logic[FONT=&quot] [/FONT]
EHF[FONT=&quot] [/FONT]
Extremely high frequency[FONT=&quot] [/FONT]
EHV[FONT=&quot] [/FONT]
Extra high voltage[FONT=&quot] [/FONT]
ELF[FONT=&quot] [/FONT]
Extremely low frequency[FONT=&quot] [/FONT]
EMF[FONT=&quot] [/FONT]
Electromotive force[FONT=&quot] [/FONT]
EMI[FONT=&quot] [/FONT]
Electromagnetic interference[FONT=&quot] [/FONT]
EW[FONT=&quot] [/FONT]
Electronic warfare [FONT=&quot][/FONT]
f [FONT=&quot][/FONT]
Frequency[FONT=&quot] [/FONT]
FET [FONT=&quot][/FONT]
Field effect transistor[FONT=&quot] [/FONT]
FF [FONT=&quot][/FONT]
Flip Flop[FONT=&quot] [/FONT]
fil [FONT=&quot][/FONT]
Filament[FONT=&quot] [/FONT]
FM [FONT=&quot][/FONT]
Frequncy modulation[FONT=&quot] [/FONT]
fr [FONT=&quot][/FONT]
Frequency at resonance[FONT=&quot] [/FONT]
fsk [FONT=&quot][/FONT]
frequency-shift keying[FONT=&quot] [/FONT]
FSD [FONT=&quot][/FONT]
Full scale deflection[FONT=&quot] [/FONT]
G [FONT=&quot][/FONT]
Gravitational force[FONT=&quot] [/FONT]
Conductance[FONT=&quot] [/FONT]
Giga (109 )[FONT=&quot] [/FONT]
H [FONT=&quot][/FONT]
Henry[FONT=&quot] [/FONT]
Magnetic field intensity[FONT=&quot] [/FONT]
Magnetizing flux[FONT=&quot] [/FONT]
h [FONT=&quot][/FONT]
hecto (102 )[FONT=&quot] [/FONT]
Hybrid[FONT=&quot] [/FONT]
HF [FONT=&quot][/FONT]
High frequency[FONT=&quot] [/FONT]
hp [FONT=&quot][/FONT]
Horsepower[FONT=&quot] [/FONT]
Hz [FONT=&quot][/FONT]
Hertz[FONT=&quot] [/FONT]
I [FONT=&quot][/FONT]
Current[FONT=&quot] [/FONT]
i [FONT=&quot][/FONT]
Instantaneous current[FONT=&quot] [/FONT]
IB [FONT=&quot][/FONT]
DC Base current[FONT=&quot] [/FONT]
IC [FONT=&quot][/FONT]
DC Collector current[FONT=&quot] [/FONT]
Integrated circuit[FONT=&quot] [/FONT]
Ie [FONT=&quot][/FONT]
Total emitter current[FONT=&quot] [/FONT]
Ieff [FONT=&quot][/FONT]
Effective current[FONT=&quot] [/FONT]
IF [FONT=&quot][/FONT]
Intermediate frequency[FONT=&quot] [/FONT]
Imax [FONT=&quot][/FONT]
Maximum current[FONT=&quot] [/FONT]
Imin [FONT=&quot][/FONT]
Minimum current[FONT=&quot] [/FONT]
I/O [FONT=&quot][/FONT]
Input/output[FONT=&quot] [/FONT]
IR [FONT=&quot][/FONT]
Infrared[FONT=&quot] [/FONT]
Resistor current[FONT=&quot] [/FONT]
IS [FONT=&quot][/FONT]
Secondary current[FONT=&quot] [/FONT]
IT [FONT=&quot][/FONT]
Total current[FONT=&quot] [/FONT]
JFET [FONT=&quot][/FONT]
Junction field effedt transistor[FONT=&quot] [/FONT]
K [FONT=&quot][/FONT]
Coefficient of coupling[FONT=&quot] [/FONT]
Kilo (103 )[FONT=&quot] [/FONT]
kHz [FONT=&quot][/FONT]
Kilohertz[FONT=&quot] [/FONT]
kV [FONT=&quot][/FONT]
Kilovolt[FONT=&quot] [/FONT]
kVA [FONT=&quot][/FONT]
Kilovoltampere[FONT=&quot] [/FONT]
kW [FONT=&quot][/FONT]
Kilowatt[FONT=&quot] [/FONT]
kWh [FONT=&quot][/FONT]
Kilowatt-hour[FONT=&quot] [/FONT]
L [FONT=&quot][/FONT]
Coil, inductance[FONT=&quot] [/FONT]
LC [FONT=&quot][/FONT]
Inductance-capacitance[FONT=&quot] [/FONT]
LCD [FONT=&quot][/FONT]
Liquid crystal display[FONT=&quot] [/FONT]
L-C-R [FONT=&quot][/FONT]
Inductance-capacitance-resistance[FONT=&quot] [/FONT]
LDR [FONT=&quot][/FONT]
Light-dependent resistor[FONT=&quot] [/FONT]
LED [FONT=&quot][/FONT]
Light emitting diode[FONT=&quot] [/FONT]
LF [FONT=&quot][/FONT]
Low frequency[FONT=&quot] [/FONT]
LM [FONT=&quot][/FONT]
Mutual inductance[FONT=&quot] [/FONT]
LNA [FONT=&quot][/FONT]
Low noise amplifier[FONT=&quot] [/FONT]
LO [FONT=&quot][/FONT]
Local oscillator[FONT=&quot] [/FONT]
LSI [FONT=&quot][/FONT]
Large scale integration[FONT=&quot] [/FONT]
LT [FONT=&quot][/FONT]
Total inductance[FONT=&quot] [/FONT]
Mega (106 )[FONT=&quot] [/FONT]
Mutual conductance[FONT=&quot] [/FONT]
MI [FONT=&quot][/FONT]
m [FONT=&quot][/FONT]
Milli (10-3 )[FONT=&quot] [/FONT]
mA [FONT=&quot][/FONT]
Milliampere[FONT=&quot] [/FONT]
mag [FONT=&quot][/FONT]
Magnetron[FONT=&quot] [/FONT]
Maximum[FONT=&quot] [/FONT]
MF [FONT=&quot][/FONT]
Medium frequency[FONT=&quot] [/FONT]
mH [FONT=&quot][/FONT]
Millihenry[FONT=&quot] [/FONT]
MHz [FONT=&quot][/FONT]
Megahertz[FONT=&quot] [/FONT]
Minimum[FONT=&quot] [/FONT]
mm [FONT=&quot][/FONT]
Millimeter[FONT=&quot] [/FONT]
mmf [FONT=&quot][/FONT]
Magnetomotive force[FONT=&quot] [/FONT]
MOS [FONT=&quot][/FONT]
Metal oxide semiconductor[FONT=&quot] [/FONT]
MOSFET [FONT=&quot][/FONT]
Metal oxide semiconductor field effect transistor[FONT=&quot] [/FONT]
MPU [FONT=&quot][/FONT]
Microprocessor unit[FONT=&quot] [/FONT]
MSI [FONT=&quot][/FONT]
Medium scale integrated circuit[FONT=&quot] [/FONT]
mV [FONT=&quot][/FONT]
Millivolt[FONT=&quot] [/FONT]
mW [FONT=&quot][/FONT]
Milliwatt
5,023
106,544
پيشوند ها و پسوند ها
پيشوند و پسوند ها : { [FONT=&quot]Prefixes[/FONT] }
[FONT=&quot]The sixteen prefixes in Table 2-6 are used to form multiples and submultiples of the SI units. The use of more than one prefix is to be avoided (e.g. pico instead of micromicro and giga instead of kilomega). The preferred pronunciation of the terms is also included in the table. The accent is on the first syllable of each prefix.
[/FONT]
  • 77.8 کیلوبایت بازدیدها: 2,748
5,023
106,544
استاندارد رنگ سيم هاي كاربردي
در الكترونيك استاندارهايي براي استفاده از رنگ سيم در دستگاه ها و مدارات در {دين EIA } وجود دارد مشاهده كنيد :
STANDARD WIRING COLOR CODES:
[FONT=&quot]Electronic applications (as established by the Electronic Industries Association – EIA):[/FONT][FONT=&quot]
[/FONT]
[FONT=&quot]Insulation Color . . . . . . .Circuit type[/FONT][FONT=&quot]
[/FONT]
[FONT=&quot]Black . . . . . . . . . . . . . . .Chassis grounds, returns, primary leads[/FONT][FONT=&quot]
[/FONT]
Blue . . . . . . . . . . . . . . . .Plate leads, transistor collectors, FET drain[FONT=&quot]
[/FONT]
Brown . . . . . . . . . . . . . .Filaments, plate start lead[FONT=&quot]
[/FONT]
Gray . . . . . . . . . . . . . . . .AC main power leads[FONT=&quot]
[/FONT]
Green . . . . . . . . . . . . . . .Transistor base, finish grid, diodes, FET gate[FONT=&quot]
[/FONT]
Orange . . . . . . . . . . . . . .Transistor base 2, screen grid[FONT=&quot]
[/FONT]
Red . . . . . . . . . . . . . . . .B plus dc power supply[FONT=&quot]
[/FONT]
Violet . . . . . . . . . . . . . . .Power supply minus[FONT=&quot]
[/FONT]
White . . . . . . . . . . . . . . .B – C minus of bias supply, AVC – AGC return[FONT=&quot]
[/FONT]
Yellow . . . . . . . . . . . . . .Emitters-cathode and transistor, FET
source
xwhoogle
تعریف ساده چند اصطلاح مهم مدارات الکترونیک
xwhoogleeeIRANTKحسین شفیعی
این اجسام برق را به خوبی از خود عبور میدهند، مثل مس وآلومینیوم واکثر فلزّات دیگر
اجسام رسانا یا هادی
برق را ازخود عبور نمیدهند، مثل لاستیک، چوب خشک ، پلاستیک، چینی
اجسام نارسانا یا عایق
این اجسام که زیاد هم نیستند، بستگی به شرایطی که بوجود می آورند، هم میتوانند برق را عبور دهند وهم میتوانند عبورندهند و هم میتوان عبوربرق را به دلخواه تنظیم کرد که چه مقدار برق عبورکند یا عبور نکند، مثل سلیکان و ژرمانیوم، بهنر است به واژه ها فعلا کاری نداشته باشید
اجسام نیمه رسانا یا نیمه هادی
فشارالکتریکی بین دو قطب مثبت و منفی را ولتاژ می گویند مثل فشاری که مابین دو سر
یک باطری شارژ شده ماشین وجود دارد وآماده است تا فشارش را به یک مصرف کننده مثلا استارت یا چراغهای ماشین وارد نماید وآنها را به کاراندازد​
واحد اندازه گیری ولتاژ، ولت است
V ولتاژ
ولتاژی که درثانیه چندین بار مثبت و منفی آن جابه جا میشود مثل برق شهرکه
دریک ثانیه 50 بار مثبت و منفی اش عوض می شود​
AC ولتاژ متناوب یا
ولتاژی که همیشه مثبت و منفی اش ثابت است گفته میشود مثل برق باطری قلمی و باطری ماشین
DC ولتاژ مستقیم یا
به حداکثرولتاژ متناوب در یک نیم سیکل، ولتاژ پیک می گویند
VP ولتاژ پیک
به حداکثر ولتاژ متناوب بین دو سیکل منفی و مثبت، ولتاژ پیک تو پیک
گفته می شود وبا اسیلسکوپ قابل اندازه گیری است، مثلا ولتاژ پیک تو​
پیک برق 220 ولت کشورمان حدود 622 ولت است
Vpp ولتاژ پیک تو پیک
به تکرار یک عمل نوسان گفته می شود
فاصله ابتدا تا انتهای موج را طول موج می گویند
نوسانطول موج
تعداد سیکل ها ی کامل دریک ثانیه را فرکانس می گویند و واحد آن هرتز است
همچنین 1000 هرتز در یک ثانیه برابر 1 کیلوهرتزاست ، واحدهایدیگری هم هستند 1مگاهرتز=100000 هرتز و1 گیگاهرتز=1000000000 هرتز
فرکانس
حرکت الکترونها از قطب منفی به قطب مثبت را جریان می گویند و واحد اندازه گیری آن آمپر است
A جریان
مقدار انرژی که یک مقاومت بصورت حرارت دریک ثانیه از دست میدهد قبل ازآنکه بسوزد، قدرت مقاومت گویند و واحد آن وات است یک میلی وات = یک هزارم وات یک کیلو وات = هزار وات یک مگا وات = یک میلیون وات
نقل از استاد ایور مجیدی --تنظیم حسین شفیعی xwhoogleee
xwhoogle
پاسخ : تعریف ساده چند اصطلاح مهم مدارات الکترونیک
بعضی دیگر اصطلاحات مدارات الکترونیک
ولتاژ ديجيتال : به ولتاژي که مقدار آن همواره ثابت بوده و در بازه زماني خاصي قطع و وصل مي شود، ولتاژ ديجيتال گفته مي شود.
VCC : تمامي ICها نياز به يک تغذيه يه صورت ولتاژ DC دارند که نام آن VCC مي باشد .
SWV : مخفف Switch Voltage به معني ولتاژ سوئيچ ميباشد .
V CORE : به VCC مورد نياز CPU ميگويند .
PWM : مخفف Pulse Width Modulation ، به معني مدلاسيون عرض پالس ميباشد ، که به مداراتي اطلاق ميشوند که توسط تنظيم ton و toff وظيفه? تهيه ولتاژ مورد نياز براي يک قطعه يا مدار خاص را دارند .
MPS : منبع تغذيه اصلي (Main Power Supply) نام دارد که به اختصار آن را MPS مي ناميم . اين مدار داراي ? فاز PWM مجزا مي باشد که هر دو فاز توسط يک IC به صورت مشترک کنترل مي شود. يکي از فازها ولتاژ ?v? و يکي ولتاژ ?v را درست مي کنند ، اين دو ولتاژ ولتاژهاي اصلي به حساب مي آيند که دستگاه چه در حالت خاموش و چه در حالت روشن باشد اين ولتاژها ساخته مي شوند، اين مدار از اين رو که سازنده ولتاژهاي اصلي مي باشد، منبع تغذيه اصلي ناميده مي شود.
مدار Switching : مداري که سه عمل Power on ، Power off و Restart را انجام مي دهد مدار Switching نام دارد .
BIOS : مرکزي در M.B ميباشد که تمامي دستورات کاري M.B و اطلاعات قطعاتي که به M.B متصل مي شود در آنجاست و مي توان آن را سيستم فرماندهي نامگذاشت. و مخفف Basic input output System ميباشد .
EC : در دستگاههاي جديد چون فعاليتهاي I / O زياد شده قسمتي از BIOS که مربوط به کنترل فعاليتهاي I/O مي باشد از IC BIOS جدا شده و در يک EP ROM مجزا قرار گرفته که EC نام دارد.
S.B : مخفف South Bridge ميباشد که همان پل جنوبي ميباشد که وظايف گوناگوني دارد .
N.B : مخفف North Bridge به معني پل شمالي ميباشد که وظيفه ارتباط بين CPU ، RAM ، VGA را دارد .
RTC: کريستال سازنده فرکانس براي S.B را ميگويند که مخفف Real Time Crystal ميباشد .
IC CHARGER : آيسي کنترل کنند ورود ولتاژ ماکزيمم ، و کنترل کننده عمليات شارژ .
IC Power : به IC مدار MPS ميگويند .
BPO : مخفف Before Power On ميباشد که به مداراتي که قبل از روشن کردن سيستم ولتاژ دارند ميگويند .
APO : مخفف After Power On ميباشد که به مداراتي ميگويند که بعد از روشن کردن سيستم به آنها ولتاژ ميرسد .
xwhoogle
ELECTRONIC
واژه های پرکاربرد دیگر در دنیای الکترونیک
A.F.cAutomatic Frequency Control = کنترل اتوماتیک فرکانس
Antenna = آنتن
Audio = صوتی
Audio tone = فرکانس ثابت صوتی (تون صوتی)
Alternating Current = جریان متناوب
Antenna gain = بهره ی آنتن
A.M - Amplitude Modulation = مدولاسیون دامنه
A.V.c- Automatic Volume Control = کنترل حجم صدا به صورت خودکار
Amplitude = دامنه
Frequency = فرکانس
Phase = فاز
Amplifier = تقویت کننده
Attenuation = تضعیف
A.G.C - Automatic Gain Control = کنترل اتوماتیک بهره
A.V.C -Automatic Voltage Control = کنترل اتوماتیک ولتاژ
B.w -Band Width = پهنای باند
Band pass
***** عبور باند
Band reject
***** حذف باند
Barkhausen
بارک هاوزن نام دانشمندی است
Block diagram
بلوک دیاگرام
Battery
باتری
Cosmic ray
اشعه ی کیهانی
Coincidence
نوعی آشکار ساز مدولاسیون فرکانس
Coaxial
هم محور
Carrier
حامل
Common
مشترک
Cascade
کاسکاد
Cut off frequency
فرکانس قطع
Criterion
اصل
Colpitts
کول پیتس نام دانشمندی که برای اولین بار فیدبک با روش تقسیم ولتاژ خازنی را ارائه کرد
Clapp
نوعی نوسانساز کول پیتس است که در آن از یک خازن سری با سیم پیچ نیز استفاده می شود
Capacitance
ظرفیت
Channel
کانال
D.C (Direct current)
جریان مستقیم
Digital
دیجیتال
Dipole
دوقطبی _ دی پل
Distortion
اعوجاج
Decibel
دسی بل
Detector
آشکار ساز
Detection
آشکارسازی
Demodutation
آشکار سازی
Demodulator
دمدولاتور _ آشکارساز
Decoupling
دکوپلاژ _ حذف ریپل
Deviation
انحراف
E.H.F (Extremely High Radio Frequency)
فرکانس رادیویی بینهایت زیاد (300ghzتا30ghz)
Earphone
گوشی
Electromagnetic
الکترومغناطیس
Fosterseely
نوعی آشکارساز اف ام
Fading
محو شدن _ به تدریج از بین رفتن
F.M (Frequency Modulation)
مدولاسیون فرکانس
Band Width
پهنای باند *****
F.E.T (Field Effect Transistor)
ترانزیستور با اثر میدان
Feed back
باز خورد _ انتقال قسمتی از انرژی خروجی مدار به ورودی به منظور کنترل خروجی
Fidility
وفاداری _ توانایی بازسازی تمام فرکانس ها در یک مدار
Ground waves
امواج زمینی
Gaurad band
باند محافظ
Gain
گین _ بهره
Ground
زمین _ شاسی
H.R.F (High Radio Frequencies)
فرکانس رادیویی زیاد (3MHZ تا 30MHZ)
Harmonic
هارمونیک _ هارمونی _ مضرب زوج یا فرد از فرکانس اصلی در موج غیر سینوسی
High pass band
***** بالا گذر
Hartly
نام دانشمندی که نوسانساز با فیدبک از طریق تقسیم کننده ی سلفی را طراحی کرد
Heterodyne
مخلوط کردن دو سیگنال با هم
High level modulation
مدولاسیون سطح بالا _ مدولاسیونی که در طبقه ی قدرت فرستنده انجام می گیرد
Infrared
اشعه ی مادون قرمز
Inter modulation
مدولاسیون تداخلی
I.F (intermediate frequency)
فرکانس میانی _ فرکانس IF
Image frequency
فرکانس تصویر _ فرکانس شبح
Jumper
اتصال دهنده
KHZ (kilo hertz)
کیلو هرتز(1000هرتز)
L.F (Low radio frequency)
فرکانس رادیویی کم (100khzتا300khz)
Load speaker
بلندگو
Line of sight
در امتداد دید
Low side frequency
فرکانس کناری پایین
L.P.F (Low Pass )
***** پایین گذر
Low level modulation
مدولاسیون سطح پایین
Oscillator
اسیلاتور _ نوسانساز
Local oscillator
اسیلاتور محلی
Message
پیام
Medium radio frequency
فرکانس متوسط رادیویی (3Mhzتا300khz)
Wave
موج
Voltage
ولتاژ
Square wave
موج مربعی
Sine wave
موج سینوسی
Saw wave
موج دندان اره ای
Satellite
ماهواره
Receiver
گیرنده
Shield
شیلد _ حفاظ
Selector
انتخاب کننده
Ultrasonic
ماوراء صوت
Ultraviolet
ماوراء بنفش
Noise
اغتشاش _ نویز
OP-amp (Operational amplifier)
تقویت کننده ی عملیاتی
Quality factor
ضریب کیفیت
Resistor
مقاومت
Radiation
تشعشع
Signal
سیگنال
Radio frequency
فرکانس رادیویی
Superconductive
ابررسانا
Microphone
میکروفون
Janction
اتصال
Purity
خالص
Im Purity
نا خالص
VP=(Peak Voltage)
ولتاژپیک ــ ولتاژ ماکزیمم
VM=(maximum voltage)
ولتاژ ماکزیمم
VP_P=(peak to peak voltage)
ولتاژ پیک تا پیک
Bias
بایاس ـ تغذیه ی dc
Forward Bias
بایاس مستقیم
Revers bias
بایاس مع***
Ifrm=(maximum repeatative peak forward current)
ماکزیمم جریان متناوب تکراری
Variable
قابل تغییر
Variation
اختلاف
Ripair
تعمیر کردن
Under repair
در دست تعمیر
Characteristic curve
منحنی مشخصه
Out put Characteristic curve
منحنی مشخصه ی خروجی
In put Characteristic curve
منحنی مشخصه ی خروجی
Qucent point
نقطه ی کار
DC load line
خط بار DC
AC load line
خط بار AC
Transistor
ترانزیستور
5,023
106,544
ضمن تقدیر و تشکر از فعالیت های بیدریغ شما دوست عزیز {
xwhoogle } و با توجه به موجود بودن تاپیکی در همین بخش - مطالب شما را به همین عنوان انتقال دادم تا ضمن عدم پراکندگی موضوعات !! دسترسی برای کاربران نیز اسانتر گردد .
xwhoogle
با سلام دوستان و اساتید گرامی --ما این سایت را کتاب خانه خصوصی خودمان میدانیم چه من مطلب بگذارم چه شما فرقی نمیکند هر چه سایت پربار و تخصصی تر پر افتخار تر پس هرچه از دستمان می آید انجام میدهیم مهم کار است نه نام--ما میرویم و کارمان میماند تا آیندگان از ته دل ما را دعا کنند و از زحمات پیش کسوت های الکترونیک در این سایت یاد کنند و نسیم معنویت و مهر و عشق را روانه دیار اخرتی ما کنند --موفق باشید
