دانلود: دامپ ( فلش ) مودم های TP-LINK ( در این تاپیک به هیچ عنوان درخواست نکنید )
arystem
38
53
TP-LINK TD-W8970 v1.x Build 140613 Rel.31066n
آپ دیت جدید رفع مشکلات ریز
Modifications and Bug Fixes:
  1. Fix the bug that LAN devices in the same group can't communicate with each other if we set Deny in Firewall.​
  2. Fix the bug that when there are a lot of files or folders in USB storage device, the web management interface will response very slowly or even crash if we add this folder in sharing path.​
  3. Fix the issue that we can't use PPPoE to dial up successfully in Surabaya of Indonesia.​
  4. Fix the bug that TD-W8970 can't dial up automatically after a reboot in Kazakhstan, Poland and Syria.​
  5. Fix the bug that it won't show ipAdEntAddr node in SNMP when WAN IP < 127.x.x.x.​
  6. Fix the bug DDNS function will stop after some time if we use EWAN mode.​
  7. Fix other known problems and bugs.​
  8. Solved initialization issue in producing.​
com-service
68
464
سلام فایل فلش مودم d-link dsl - 124
d-link dsl-124 hw ver l1 fw v01.00.07 do anten moststil
