نرم افزارهای خودتان را به طور کامل از کامپیوتر حذف کنید Your Uninstaller PRO v7.3.2011.02
6,774
29,826
دوستان این نرم افزار وقتی برنامه رو حذف میکنید علاوه بر حذف معمولی برنامه تمام فایلهایی که از اون برنامه به جای میمونه و همه کلیدهایی که در رجیستری ایجاد کرده رو نیز حذف میکنه که به صورت معمول حذف نمیشن. تقریبا بیشتر آثار اونها رو از بین میبره.
همچنین اگر نرم افزاری فایل unistall اون از بین رفته باشه یا به صورت کامل حذف نشده باشه میتوانید با این نرم افزار به صورت کامل حذف و از لیست برنامه ها نیز حذفش کنید
دانلود با حجم 7.10 MB
[hide]
[DL]http://uploadorb.com/gl5uvntefev4[/DL]
[/hide]​
Installing and uninstalling programs are very common in this broadband world. People download programs every day and install them, lucky ones get the chance to serve you, but the others, they have to go.
OK, problems here: some programs are lazy and they won't take everything they brought here. They may leave files under Windows, unused Dll libraries, junk files and tons of registry keys. It's not the worst, some of them even prevent to be uninstalled, it always pops up a square dialog and tells you: "*** is damaged, I could not be uninstalled." Even reinstalling the program will not help. It's really annoying and absolutely, unacceptable!
That's why you are reading this, you are in the right place! Your Uninstaller! is designed to solve any uninstall related problems and remove everything related, what you need is simply locate the program and hit "Uninstall", after simply clicks, it will be gone - with everything it brought. Your Uninstaller! also has advanced features for experienced users.
Removing all unwanted programs will keep your system clean and stable.
Your Uninstaller! completely replaces the built-in Add/Remove program, with more reliable features. If you are familiar using the standard Add/Remove program, there's no difficulty using Your Uninstaller!.
FEATURES AND BENEFITS :
* Uninstall any installed program completely, even corrupted ones.
* Fix invalid uninstalls in one click.
* Full system scan after a program is uninstalled for complete removal.
* Force removal of a program.
* Keep your system stable and clean with various system tools.
* Easy to Use. No expert knowledge required.
* Windows Vista and Windows 7 Compatible.
* Safe and Trusted.
6,774
29,826
خواهش میکنم.
دوست عزیز خیلی آپلود سنترها در ایران فیلتــر شدن بهتره از مستقیم کننده های رایگان استفاده کنید
من یک جای دیگه براتون آپلود کردم که فیلتــر نیست و امکان ریزم و بدون محدودیت سرعت هم داره
همان پست اول رو ویرایش کردم دوباره دانلود بفرمایید
انشا الله از دو روز دیگه هر چی فایل براتون تو سایت بگذارم ت مدیا فایر آپلود میکنم که دیگه محدودیت فیلتــر نداشته باشید و کیفیت خوبی هم اون سایت ارائه میده
