ورژن جدید نرم افزار فتوشاپ برای گوشی شما
6,787
29,884
دوستان این نرم افزار یکی از بهترین نرم افزارهای ادیت عکس و همچنین کشیددن نقاشی در گوشی هست که ورژن جدیدش رو برای شما عزیزان قرار می دم.
امیدوارم بدردتون بخوره:eek:k:
ProPaint Mobile v1.6 J2ME
ProPaint Mobile v1.6 J2ME [EN/RU] -mobile graphic editor/paint program
The graphic editor with the beautiful interface and the big possibilities. Allows both create the drawings, and to edit the existing. Also there is a possibility without leaving the appendix to receive photos from the chamber, to grasp shots from video, tocollect animation from pictures of any format etc. The set of effects, tools is accessible, also there is a support of graphic fonts and a brush.
Change Log :
- Fixed a bug with obtaining a transparent color in the Color Picker tool. As a consequence, began working as an angular gradient.
- Added support for transparency in the tool point, Paintbrush, nets, lines and polylines (if the thickness is greater than 1).
- Tool Blurring transformed into an instrument of effectors. Now it can set different effects.
- Added support for the thickness of the lines in the Bezier curve.
- The thickness of the brush (including downloadable braces) now depends on the thickness of the line chosen in the settings.
- Added the effect of inclination (horizontal and vertical).
- Added a tool for background fill, as one of the parameters of the fill.
- Fixed a bug with the creation of images at one pixel in size of the raster.
- New version PPMBrushEditor.
- Added tool Tag.
