نمایش تمامی پروسه های در حال اجرا | Process Monitor 2.95
6,787
29,883
Process Monitor 2.95 portable
نمایش تمام پروسه های در حال اجرای ویندوز. چه پروسه هایی که مخفی هستند و چه آنها که مخفی هستند و همچنین نمایش تمام پروسه هایی که توسط فایلها اجرا شدند یا از رجیستری اجرا شده و ...... و به صورت انلاین پروسه ها رو که در حال انجام کار هستند سریع لیست میکنه و همینجور اسکرول میکنه پایین ....تا زمانی که برنامه رو ببندید
اصلا هر چی که فکر کنید نشون مید!
لینک دانلود با قابلیت ریزم
[hide][DL]http://uploadorb.com/dq5m7j043gne[/DL][/hide]
Process Monitor is an advanced system monitoring tool that enables you to monitor file system, Registry and process/thread activity in real-time. It offers ******s and highlighting rules that enables you to limit and focus the monitoring to processes that match certain conditions. The captured activity can be viewed in real-time and also saved and exported to file. Other features include boot-time logging, configurable display columns, advanced process properties, summary reports and much more.
Process Monitor includes powerful monitoring and f i lterining capabilities, including:
-More data captured for operation input and output parameters
-Non-destructive ******s allow you to set ******s without losing data
-Capture of thread stacks for each operation make it possible in many cases to identify the root cause of an operation
-Reliable capture of process details, including image path, command line, user and session ID
-Configurable and moveable columns for any event property
-******s can be set for any data field, including fields not configured as columns
-Advanced logging architecture scales to tens of millions of captured events and gigabytes of log data
-Process tree tool shows relationship of all processes referenced in a trace
-Native log format preserves all data for loading in a different Process Monitor instance
-Process tooltip for easy viewing of process image information
-Detail tooltip allows convenient access to formatted data that doesn't fit in the column
Cancellable search
-Boot time logging of all operations
