آموزشی: لیست ماژول های هارد های وسترن
chelib
47
81
34
اینم لیست تمامی ماژول های هارد وسترن همراه با ID  و عنوان.برای تعمیر هارد و ریکاوری کردن اشنایی با تمامی ماژول هارد دیسک الزامی میباشد.با نرم افزار Sediv و WDR  یا WDRmarvel  راحت اقدام به ریست ماژول کنید
WD module functionID01 = DIR(module directory)
ID02 = parameter / password module
ID03 = Dan table
ID04 = Dan table's primary backup
ID05 = dan Table 1 spare
Dan Table spare ID06 = 2
ID07 = dan Table spare 3
ID0A = head map
ID0B = Flash ROM directory
ID0D = Flash configuration
ID0C = list of models
ID11 = Overlay (ATA module)
ID12 = bootloader
bootloader ID13 =
ID14 = boot program
ID15 = boot program
ID17 = two sector table (usually empty)
ID19 = bootloader
ID1B = Bootloader
ID1C = boot program
ID1C = Form
ID1E = bootloader
ID1F = boot program
ID20 = SMART & current log
ID21 = SMART & current log
ID22 = SMART & current log
ID23 = SMART & log removal
ID24 = SMART & primary log
ID25 = SMART Log 80h-9Fh Host Vendor specific
ID26 = SMART Log A0h-B7h DLGDIAG Log
ID28 = automatic calibration process
ID29 = Form 1_0
1_1 ID2A = form
ID2D = SMART Log - Dump RAM
ID2E = SMART Log - Dump RAM
ID2F = Overlay
ID30 = Decoding Table: Firmware District
ID31 = Decode Table: P-LIST
ID32 = decode table: G-LIST
ID33 = defect table: P-LIST
ID34 = defect table: G-LIST
ID35 = defect table: Firmware District
ID36 = defect table: track
ID37 = Gain Call Data Module
ID38 = bootloader
bootloader ID39 =
ID40 = adaptation parameters: User Area
ID41 = adaptive
ID42 = adaptive
ID43 = adaptive
ID46 = adaptive: Copy to ID 40
ID unit 47 = adaptation parameters: FirmwareDistrict
ID49 = adaptive
ID4A = adaptive
ID4C = boot program
ID4D = adaptive
ID4E = boot program
ID4F = microcode versions
ID50 = Form MAIN
ID 51 = Form ALT1
ID52 = Form ALT2
ID 53 = Form ALT3
ID60 = Clear
ID6B = bootloader
ID6E = boot program
ID6F = boot program
ID90 = Calibration: log
ID91 = Calibration: log
ID92 = Calibration: log
ID93 = Calibration: Log
ID9E = Calibration: Log
IDB1 = simple test
IDB5 = WRRO log module
IDB6 = factory in self-test module
IDB7 = test Data
IDB8 = self-calibration table
IDB9 = low-level formatting
IDBA = SPT read all
IDBB = SPT all written
IDBC = STP Depop
IDBD = self-calibration table: Clear
IDBE = self-calibration table: Clear
IDBF = self-calibration tables: Table
IDC0 = Calibration: Log
IDC1 = Calibration: Log
IDC2 = Calibration: Log
IDC3 = Adjust track density
IDC4 = head read parameters / cornice heightadjustment
IDC5 = Calibration: DCM Codes
IDC7 = Calibration: Log
IDC8 = adjusts the sector density
IDCA = Calibration: Log
IDCB = Calibration: Log
IDCC = Calibration: Log
IDCD = Calibration: Log
IDCE = Calibration: Log
IDCF = Calibration: Log
IDD1 = scan defects (write) and add LOG
IDD0 = polishing test
IDD2 = plus P-LIST
IDD3 = handle the number of sectors
IDD4 = Test Track defects
IDD5 = test cluster
IDD6 = Calibration: Test
IDD7 = PE scan test
IDD9 = Erase Block Test
IDDA = Calibration: Test
IDDB = scan defects (read) and add LOG
IDDC ​​= Test Xmit Blink
IDDD = gain calibration
IDDE = self-calibration:
IDDF = Mini test
IDE0 = factory defects in self-test log
IDE1 = factory defects in self-test log
IDE2 = factory defects in self-test log
IDE3 = factory defects in self-test log
IDE4 = factory defects in self-test log
IDE5 = factory defects in self-test log
IDE6 = factory in self-test log
IDE7 = factory in self-test parameter module
IDE8 = Calibration: Log
IDE9 = Calibration: Log
IDEE = Calibration: Log
IDF0 = Calibration: Log
IDF1 = Calibration: Log
IDF7 = purge unit time error data
IDFA = Calibration: Log
IDFB = Calibration: Log
IDFC = Calibration: Log
IDFD = Calibration: Log
IDFE = Calibration: Log
ID0102 = Copy of id0A
ID0103 = Copy of id0D + ID unit 47
ID0105 = Copy of ID30
= Copy of id0B ID0107
ID0108 = Overlay
ID0109 = Copy of Flash Code
ID1000 = Sector NULL
ID 1001 = self-calibration bootloader
ID1002 = self-calibration bootloader
ID1003 = self-calibration bootloader
ID2000 = Head 0 Mrjog / parameter adjustment log
ID2001 = Head 1 Mrjog / parameter adjustment log
ID2002 = Head 2 Mrjog / parameter adjustment log
ID2003 = Head 3 Mrjog / parameter adjustment log
ID2004 = Head 4 Mrjog / parameter adjustment log
ID2005 = Head 5 Mrjog / parameter adjustment log
ID2006 = Head 6 Mrjog / parameter adjustment log
ID2007 = Head 7 Mrjog / parameter adjustment log
ID2010 = Head 0 departmental test log
ID2011 = Head 1 Sector test log
ID2012 = Head 2 departments test log
ID2013 = Head 3 departments test log
ID2014 = Head 4 departments test log
ID2015 = Head 5 departments test log
ID2016 = Head 6 departments test log
ID2017 = Head 7 departments test log
ID2020 = Head 0 read / write test log
ID2021 = Head 1 read / write test log
ID2022 = Head 2 read / write test log
ID2023 = Head 3 read / write test log
ID2024 = Head 4 read / write test Log
ID2025 = Head 5 read / write test log
ID2026 = Head 6 read / write test log
ID2027 = Head 7 read / write test log
ID2030 = Head 0 track test log
ID2031 = Head 1 track test log
ID2032 = Head 2 track test log
ID2033 = Head 3 track test log
ID2034 = Head 4 tracks test log
ID2035 = Head 5 track test log
ID2036 = Head 6 tracks test log
ID2037 = Head 7 tracks test log
ID2040 = Head 0 channel parameter host test log
ID2041 = Head 1 channel parameters Host test log
ID2042 = Head 2 channel parameter host test log
ID2043 = Head 3 channel parameter host test log
ID2044 = Head 4 channel parameter host test log
ID2045 = Head 5 channel parameter host test log
ID2046 = Head 6 channel parameter host test log
ID2047 = Head 7 channel parameter host test log
ID2050 = Head 0 ZoneAllcation parameteradjustment log
ID2051 = Head 1 ZoneAllcation parameteradjustment log
ID2052 = Head 2 ZoneAllcation parameteradjustment log
ID2053 = Head 3 ZoneAllcation parameteradjustment log
ID2054 = Head 4 ZoneAllcation parameteradjustment log
ID2055 = Head 5 ZoneAllcation parameteradjustment log
ID2056 = Head 6 ZoneAllcation parameter adjustmentlog
ID2057 = Head 7 ZoneAllcation parameteradjustment log
ID2060 = Head 0 channel parameter validation /Sign
ID2061 = Head 1 channel parameter validation /Sign
ID2062 = Head 2 channel parameter validation /Register Login
ID2063 = Head 3 channel parameter validation /Sign
ID2064 = Head 4 channel parameter validation /Sign
ID2065 = Head 5 channel parameter validation /Sign
ID2066 = Head 6 channel parameter validation /Sign
ID2067 = Head 7 channel parameter validation /Register Login
ID8000 = Test List?
ID8001 = log
ID8002 = log
ID8003 = IBI-Data config String (+ Model /serial)
ID8004 = Sript Headers?
ID8005 = log
ID8006 = log
ID8007 = log
ID8008 = log
ID8009 = log
ID800A =log
