ساخت آلبوم خانوادگی و عروسی با پخش آهنگ و ... | Wedding Album Maker Gold 3.20
6,787
29,883
با این نرم افزار هم می تونید آلبومهای خیلی زیبا و خاطره انگیزی درست کنید مخصوصا که همزمان با پخش آلبوم با جلوه های ویژه آهنگ هم پخش میکنه که می تونید از آهنگهای شب عروسی استفاده کنید... حتی می توانید بک گراند براش تعیین کنید و خیلی کارهای جالب دیگه
حجم نرم افزار هم 22 مگابایت بیشتر نیست.
برای دیدن سایز اصلی عکس بر روی آن کلیک کنید
لینک دانلود (با قابلیت ریزم و بدون محدودیت سرعت)
[hide][DL]http://ifile.it/82aezvx/WAMaker_Gold_3.20-irantk.zip[/DL][/hide]
Wedding Album Maker is an easy-to-use software which allows you to create an amazing wedding photo album with background music, Pan&Zoom and transition effects. With Wedding Album Maker, you can quickly and easily produce professional-looking wedding photo slideshow DVD disc and share your love story and excitement of your wedding day on home big screen TV with standard DVD player in the comfort of your living room.
Looking for slideshow software to share your lovely moments with family and friends? If so, you definitely need Wedding Album Maker. Sharing and viewing wedding photos in a slide show software format with friends and family has never been easier! With Wedding Album Maker, you can use your CD or DVD burner to make high quality photo slide show DVD disc in less than half an hour by yourself.
Key features of Wedding Album Maker include:
• No Experience Necessary
Wedding Album Maker is simply the easiest to use slideshow software. It is designed to be easy enough for anyone in the family to use. You can create dynamic wedding slideshows with just clicks: Add your photos, design your movie menu, and burn your disc. You will find that you can perform all tasks in the most natural and intuitive way.
• All-in-One Wedding Photo Album Maker
There's no need for other CD or DVD burning software. Wedding Album Maker can do all from the beginning to the end to make a DVD slideshow. And, the whole steps are simple, fast and robust: the Burn-Proof (TM) technique which makes the DVD burning procedure more robust than ever!
• Lovely Music, Transition Effects
Burn your slideshow with DVD motion menus and transition effects to DVD and watch it on TV using your DVD player. The slideshow editor includes all the tools you need to create eye-catching photo presentations. Wedding Album Maker enables you to add your favorite wedding music for your wedding slide show. We provide some of the most visually elegant effects available in the market. You can even customize many of these effects, giving you a virtually infinite selection.
• Highest Resolution Format On TV
Wedding Album Maker optimizes your digital photo and uses the Highest Resolution format which is supported by most DVD players. This technique makes photo look great on TV.
• Professional Hollywood-style DVD Menu Templates
Wedding Album Maker features a library of professionally designed menu backgrounds and frames. Ranging from playful to professional, you're sure to find a background for any occasion.
• Decorate Wedding Photos with Text and Arc Clips
The built-in What You See is What You Get photo editor makes it easy to add your own comments for your wedding photos. The position, font, color and shadow of the text are immediately shown with the photo. It also supports Art-clips for each photo slide which adds amazing special effects for your wedding slideshow.
OS : Win XP/2000/Vista/Win 7
Language : English​
