ریکاوری فایلها با LC-TECH FILERECOVERY 2011 v5.0.0.11
6,787
29,883
با سلام دوستان. این نرم افزار یکی از نرم افزارهای خیلی خوب در زمینه بدست آوردن فایلهای از دست رفته از سیتم هست. اگر فایلی رو اشتباهی پاک کردید یا به هر نوحو اون رو از دست دادید شانس دارید که دوباره با این نرم افزار فایل رو بازیابی کنید
دانلود با حجم 5 مگابایت با قابلیت ریزم و بدون محدودیت
[hide][DL]http://ifile.it/7eiatqc/LC-TECH.FILERECOVERY.2011.for.Windows.Enterprise.v5.0.0.11-TE-www.irantk.ir.rar[/DL][/hide]
توضیحات سایت سازنده:
FILERECOVERY is a safe and affordable do-it-yourself data recovery solution that is designed to recover lost and deleted files from all types of media such as hard drives, optical drives, flash media drives, and multi-media or mobile devices
FILERECOVERY recovers files whether they have been deleted from the command line, from within an application, the file system, or removed from the recycle bin.
In addition FILERECOVERY recovers formatted or lost drives, drives with a severe logical file system damage, and can even reconstruct lost RAIDs
Supported Operating Systems and File Systems
FILERECOVERY for the PC runs natively under the Windows 2000/XP/2003/Vista/Win7 operating systems, and supports all partitions using FAT 12, FAT16, FAT32, and NTFS file systems. It will also allow scanning and recovery from HFS formatted volumes as well
Features
- Easy to use wizard driven interface
- Ability to scan all volumes in a local machine and build a directory tree of lost and deleted files
- Search lost and deleted files matching file name criteria
- Fast scanning engine allows the file list to be built quickly
- Easy to understand File Manager and typical Save File dialog
- Secure data recovery: FILERECOVERY does not write on the drive it is scanning
- Saving data to any drive is possible, including network drives, removable media, etc
- PC version supports compressed and encrypted files for Windows NTFS
Home Page -
کد:
http://lc-tech.com/
