تاسک منیجر بسیار عالی Smartphoneware Best TaskMan v2.4
6,787
29,883
Smartphoneware Best TaskMan v2.4 S60v3 S60v5 SymbianOS9.x Unsigned Crcked-FoXPDA
دوستان این یک تاسک منیجر بسیار عالی برای مدیریت برنامه های در حال اجرا و بستن اونهاست. فکر می کنم از عکس بفهمید کارش چجوریه
When you get a voice call, no matter what application you're in, you always have instant access to it. Why getting a new messageshould be different on your phone?
FS Message application shows incoming text message on full screen instantly when it comes. You've heard incoming message sound? Just take the phone out of your pocket to see the message on the screen already.
Too busy to check your phone screen? No problem, the program can read aloud the sender's name or the entire incoming message to your phone loudspeaker or headset using text-to-speech engine.
If the text message is too large and does not fit the screen you can scroll it up and down. Additionally it shows all unread messages and you can switch between them very fast with left/right keys.
You can mark the message as read, reply it, call back to the sender, delete the message or open it in messaging application.
Features include
Shows message in full screen
Can read the sender's name or the entire incoming message aloud when it comes.
Supports 4 levels of message zoom
Large fonts suitable for people with weak eyesight can be used to display a message
Supports message scrolling
Shows all unread messages
Mark message as read, reply, call back, and delete
Service based application - works in background and is absolutely transparent to the user
What's new in v2.04
Both S60 3rd edition and S60 5th edition are in one installation file now.
واکنش‌ها[ی پسندها]: Masoud_Y
