برنامه Fake Message v1.10.9 Unsigned
6,788
29,890
The new version of the application, which can at times you select to send to your smartphone "false" SMS-message, which you do in advance and is by specifying the desired number of the sender, message text and sending time.This network is not used, all done programmatically within the smartphone.
Update:
*. added new language localization.;
*. fix bugs.
After the installation menu smartphone created folder DrJukka, where to actually install applications from this developer.
واکنش‌ها[ی پسندها]: Masoud_Y
