ایجاد شرت کات برای همه چیز! SymbianGuru CuteKeys v2.0
6,787
29,883
SymbianGuru CuteKeys v2.0 S60v3 SymbianOS.x Signed
دوستان این یه برنامه کاربردی مخصوص سری 60v3 میباشد که میشه به راحتی هر چه تمام کلید میانبر واسه برنا مه هاتون بزارین مثلا با یک کلید وارد بلوتوث شوید با یه کلید وارد اس ام اس شوید و واسه تمام برنامه ها میتونید میانبر بسازید
Cute Keys creates keyboard shortcuts for the wide range of actions. It saves your time while opening an application, multimedia file or document; sending SMS, MMS or Email; opening a chosen contact or changing the Bluetooth status. Easy and quick work withyour mobile using Cute Keys!
General information:
Cute Keys is a Series 60 v 3 productivity application for creating keyboard shortcuts and performing different actions on hotkeypressing. With Cute Keys you can create shortcuts for following actions:
* Open chosen application installed on the mobile
* Open selected multimedia file or document
* Call a certain recipient
* Open selected contact from your contact book
* Change Bluetooth status
* Send SMS/MMS/eMail to selected recipient
* Browse selected website
Every shortcut is set of two, three, or even four buttons on your mobile keyboard. Mostly you can use two buttons, one of which is a special button, and the second one is a number button. Mobiles with QWERTY keyboard allow more possibilities; there you cancreate the shortcuts similar as you do on your PC.
There is no limit for the number of shortcuts created, their number is only limited by the hardware.
Please note:You can not use two number buttons in one shortcut, you have to use at least one special button or joystick.
Cute Keys in action:
Cute Keys is very easy to operate. You have to create new shortcut inside of the application, choosing the name for it, the action to be performed and the key combination. After this you may exit the Cute Keys application.
Now, if you shortly press the buttons combination that you have set for the certain action, this action will be executed. For example, if you have set “*​
