نرم افزار ImmoKiller v1.10
tx-mafia
332
2,639
ecu هایی که ساپورت میشه توسط این نرم افزار
Remove Immo - ECU works without immo
No description - ECU cleared and prepared for coding / autocoding
Alfa Romeo 2.4 JTD Bosch 24C04
Audi A3,A4,A6 Bosch 1.8 Turbo 24C02 (Remove Immo)
BMW Bosch 318 TDS 93C46 (Remove Immo)
Chrysler Voyager 2.5 TD, Bosch 24C02 (Remove Immo)
Citroen IAW G6.14 - Magneti Marelli
Citroen Berlingo - BSI - MCU NEC
Citroen C3- BSI - MEM 95160
Citroen Xara - BSI - MEM 95040
Citroen Xara Picasso - BSI - MEM 95040
Citroen EDC15 5P08C3 (Remove Immo)
Citroen MA 3.0 Bosch 93CS46 (Remove Immo)
Citroen MA 3.1 Bosch 24C04 (Remove Immo)
Citroen MA 3.1 Bosch 93CS46 (Remove Immo)
Citroen MP 3.2 Bosch 93CS46 (Remove Immo)
Citroen MP 5.2 Bosch 93S46 (Remove Immo)
Citroen MP 7.2 Bosch 24C02 (Remove Immo)
Citroen MP 7.3 Bosch 24C02 (Remove Immo)
Citroen SID 803 PIN calculator (95320)
Citroen SID 803 PIN programmer (95320)
Daewoo Siemens TMS374
Fiat Bosch - 24C02
Fiat IAW 16F.EB - Magneti Mirelli
Fiat IAW 4AF.M9 - Magneti Marelli
Fiat 2.3 JTD Bosch 5P08C3
Fiat BPKA DELCO HC11F1
Fiat Hitachi MFI 003BC2 59C11
Fiat IAW 8F.5T Magneti Marelli HC11E9
Fiat IAW 8F.6B Magneti Marelli HC11E9
Fiat IAW 18F.B4 Magneti Marelli HC11F1
Fiat IAW 1ABB.92 TMS374
Fiat IAW 1ABG.81 Magneti Marelli TMS374
Fiat IAW 1AF.13 Magneti Marelli TMS374
Fiat IAW 1AF.15 Magneti Marelli TMS374
Fiat IAW 1AF.17 Magneti Marelli TMS374
Fiat IAW 1G7SP.71 Magneti Marelli HC11F1 (c/r immo)
Fiat IAW 49F.B4 Magneti Marelli 95040
Fiat IAW 4AF.M1 Magneti Marelli 95160
Fiat IAW 4AF.M7 Magneti Marelli 95160
Fiat IAW 4AF.S2 Magneti Marelli 95160
Fiat IAW 59F.M2 (HYBRID)
Fiat IAW 59F.M3 (HYBRID)
Fiat IAW 59F.M7 (HYBRID)
Fiat IAW 59F.M9 (HYBRID)
Fiat IAW 5NF.T1 Magneti Marelli 95160
Fiat IAW 8F.5T Magneti Marelli HC11F1
Fiat IAW 8P.22 Magneti Marelli HC11
Fiat Lucas DCU3F 95080
Iveco Daily Bosch 24C16
Kia Clarus 2.0 16V Bosch 24C02
Kia Siemens TMS374
Mazda 323 Diesel Denso 93C56
Mercedes A class - Siemens/VDO 29F200
Mercedes C,E class (infra-red) - ECU progr. ?
Mercedes C,E class (infra-red) - Immo progr. 2/2
Mercedes EDC16 95320 - Unlock ECU
Mercedes Sprinter 24C02 - Unlock ECU
Mercedes Sprinter 5P08C3 - Unlock ECU
Mercedes Start Error - Sprinter
Mercedes Start Error - Sprinter (EWS OK)
Mercedes Start Error - Vito HC05
Mercedes Start Error - Vito HC08
Mercedes Vito 24C04 - Unlock ECU
Opel Delco HC11F1 2 plugs (blue,grey)
Opel DELCO HC11F1 2 plugs (red,white)
Opel DTL - Bosch
Opel Motronic based on 24C02 - Bosch
Opel Siemens SIMTEC 56.1 9356
Opel 1.2 8V Delco 27C256 (Remove Immo)
Opel 1.7 ; 2.0 16V Turbo Diesel 24C04 (Remove Immo)
Opel 2.5 Turbo Diesel 2x93C46 (Remove Immo)
Opel Bosch DTL 24C04 + 2x29F010
Opel Siemens SIMTEC 56.1 - 29F010 (Remove Immo)
Peugeot MP5.1.1 - Bosch
Peugeot S2000 - Sagem (95080)
Peugeot S2000 RPM - Sagem (95080)
Peugeot S2000 - Sagem (95080) PIN progr.
Peugeot BSI - De/encryption
Peugeot ECU Bosch ME7.4.4 PIN progr.
Peugeot ECU Bosch ME7.4.4 PIN calc.
Peugeot EDC 15 - 5P08C3 PIN prog.
Peugeot EDC 16 - 95160 PIN prog.
Peugeot EDC15 PIN calculator (5P08C3)
Peugeot EDC16 PIN calculator (95160)
Peugeot EDC16 (95640) - Remove Immo
Peugeot 206 BSI - MCU HC912
Peugeot 206 BSI - MEM 95160
Peugeot 307 BSI - MCU HC912
Peugeot 307 BSI - MEM 95160
Peugeot 2.3 JTD Bosch 5P08C3
Peugeot IAW 1AP.20,90 TMS374
Peugeot IAW 1AP.41 Magneti Marelli TMS374
Peugeot IAW 1AP.43 Magneti Marelli TMS374
Peugeot IAW 1AP.80, 81, 40 TMS374
Peugeot IAW 1AP.83 Magneti Marelli TMS374
Peugeot IAW 48P2.XX Magneti Marelli 29F400
Peugeot IAW 6LP2.02 Magneti Marelli ST10F280
Peugeot IAW 8P.XX Magneti Marelli HC11A8 MCU
Peugeot Sagem SL96 TMS374 1x28F512
Peugeot Sagem SL96 TMS374 2x28F512
Polonez Delco HC11F1
Renault 5NR.XX - Magneti Marelli
Renault DCI - Bosch
Renault DCI - Delphi
Renault DCI - Delphi (remove crash blockade)
Renault DCU3R - Lucas, Clear Immo
Renault DCU3R - Lucas, Remove Immo
Renault Megane 2 (clear steering lock) 24C04
Renault SIRIUS32 - Siemens
Renault SIRIUS34 - Siemens
Renault SIRIUS35 - Siemens
Renault 1.9 DTI Bosch 24C04 (1 plug), (Remove Immo)
Renault 1.9 DTI Bosch 24C04 (2 plugs)
Renault Fenix 3 95160
Renault IAW 6R.20 Magneti Marelli TMS370
Renault IAW 6R.30 Magneti Marelli TMS370
Renault IAW5NR2.XX 95160
Renault IAW 8R.30 HC11A1 MM (Remove Immo)
Renault MP7.0 Bosch 24C02, (Remove Immo)
Renault S2000RPM 95080 - SAGEM
Renault Siemens TMS374
Renault Sirius32 (16V) 29F200 (Remove Immo)
Rover 214,216 93C46
Skoda SIMOS - Siemens
Toyota 93LC66 + Texas 4C (Key programmer)
Toyota YarisDenso 93C46
V.A.G EDC16 Remove Immo (95320)
V.A.G. EDC16 Bosch 95320
V.A.G IMMO 5WK4 678 - HC05 - Siemens
V.A.G IMMO 6X0 953 257 - 24C04 - Valeo
V.A.G IMMO VW LT - HC05X16
V.A.G IMMO White box - 93C46 - f+g Megamos
V.A.G. ME7.1.(x) - 7.5.(x) Remove Immo Bosch 95040
V.A.G. SIMOS - Siemens, 93C76, (Remove Immo)
V.A.G. TDI - Bosch
V.A.G. TDI 24C02 (1 plug) Bosch
V.A.G. TDI 24C02 (2 plugs) Bosch
ALFA ROMEO:
1. Repair ECU, Remove Immo - BOSCH Twin Spark (Alfa Model 156), BOSCH 0 261 204 772 - 24C02 memory
2. Repair ECU - BOSCH JTD 2.4 5 plugs 24C04 memory
AUDI:
1. Audi A2 - PIN decoder loaded 93C86-16
2. ECU - Bosch 1,8 Turbo with 24C02 memory, BOSCH 0 261 204 678,778,818,805
BMW:
1. BMW 318 TDS Bosch 0 281 001 243 - 93C46(B58323)
2. REPAIR ECU BMW 2.0L - 2.8L on Siemens MS41.0 DME 29F200
CITROEN:
1. Calculate - Citroen Berlingo/BSI - MCU NEC
2. Calculate - Citroen C3/BSI - MEM 95160
3. Calculate - Citroen Xara/BSI - MEM 95040
4. Calculate - Citroen Xara Picasso/BSI - MEM 95040
5. Decrypt-Encrypt Citroen/Peugeot dump-file
6. Programm Citroen/Peugeot EDC15 PIN MEM 5P08C3
7. Programm Citroen/Peugeot EDC16 PIN MEM 95160
8. Programm Citroen/Peugeot ECU ME 7.4.4 Bosch
9. Repair ECU - MAGNETI MARELLI IAW G 6.14 (Model ZX), ECU - with HC11 Motorola/Toshiba mcu
10. Repair ECU - Citroen/Peugeot EDC15 5P08C3 PIN (Remove Immo action)
11. Repair ECU - Citroen Saxo 1,6 - 8 Valves, ECU Bosch MP5.2 93S46 - Remove Immo action
12. Repair ECU - Citroen Saxo 1,0 - ECU Bosch MA3.1 24C02 - Remove Immo action
13. Calculate PIN Citroen/Peugeot EDC15 PIN 95P08
14. Calculate PIN Citroen/Peugeot EDC16 PIN 95160
15. Repair ECU - PSA - ECU Bosch MP7.2 24C02 - Remove Immo action
16. Repair ECU - PSA - ECU Bosch MP7.3 24C02 - Remove Immo action
17. Repair ECU - PSA - ECU Bosch MA 3.0 93S46 - Remove Immo action
18. Repair ECU - PSA - ECU Bosch MA 3.1 93S46 - Remove Immo action
19. Repair ECU - PSA - ECU Bosch MA 3.2 93S46 - Remove Immo action
20. Calculate PIN - Citroen/Peugeot SID803 ECU Siemens MEM 95320
21. Programm PIN - Citroen/Peugeot SID803 ECU Siemens MEM 95320
22. Calculate PIN - Citroen/Peugeot Bosch ECU ME 7.4.4
FIAT:
1. Repair ECU - BOSCH with 24C02 memory ECU - BOSCH 0 261 204 405
2. Repair ECU - MAGNETI MARELLI IAW 5NF.T1 with 95160
3. Repair ECU - MAGNETI MARELLI IAW 16F.XX with HC11F1 MCU
4. Repair ECU - MAGNETI MARELLI IAW 1ABB.92 with TMS374 MCU
5. Repair ECU - MAGNETI MARELLI IAW 1AF.1G with TMS374 MCU
6. Repair ECU - HITACHI MFI 003BC2 with 59C11 MEM
7. Repair ECU - BOSCH 0 281 010 488 with 5P08C3 MEM 95P08
8. Repair ECU - MAGNETI MARELLI IAW 4AF.M1 with 95160
9. Repair ECU - MAGNETI MARELLI IAW 4AF.M7 with 95160
10. Repair ECU - MAGNETI MARELLI IAW 4AF.M9 with 95160
11. Repair ECU - MAGNETI MARELLI IAW 4AF.S2 with 95160
12. Repair ECU - MAGNETI MARELLI IAW 8P.22 with HC11 mcu
13. Repair ECU - MAGNETI MARELLI IAW 18F.XX with HC11F1 mcu
14. Repair ECU - MAGNETI MARELLI IAW 49F.B4 with 95040
15. Repair ECU - MAGNETI MARELLI IAW 8F.5T with HC11E9 mcu
16. Repair ECU - MAGNETI MARELLI IAW 8F.6B with HC11E9 mcu
17. Repair ECU - DELCO BPKA 2 plugs(beige+red) 18. Repair ECU - MAGNETI MARELLI IAW 59F.M2 (Hybrid) 95080
19. Repair ECU - MAGNETI MARELLI IAW 59F.M3 (Hybrid) 95080
20. Repair ECU - MAGNETI MARELLI IAW 59F.M7 (Hybrid) 95080
21. Repair ECU - MAGNETI MARELLI IAW 59F.M9 (Hybrid) 95080
22. Repair ECU - LUCAS DCU3F with 95080 memory
23. Repair ECU - IAW 8F.5T with Magneti Marelli HC11F1 mcu
24. Repair ECU - MAGNETI MARELLI IAW 1AF.13 with TMS374 MCU
25. Repair ECU - MAGNETI MARELLI IAW 1AF.15 with TMS374 MCU
26. Repair ECU - MAGNETI MARELLI IAW 1AF.17 with TMS374 MCU
27. Repair ECU - MAGNETI MARELLI IAW 1ABG.81 with TMS374 MCU
28. Repair ECU - MAGNETI MARELLI 1G7SP.71 with HC11F1 MCU (C/R immo)
Clear immo solution, for remove immo - cut immobiliser line
KIA:
1. Repair ECU - SIEMENS K103735120A with TMS374 MCU
2. Repair ECU - BOSCH Engine 2.0 16V with 24C02
MAZDA:
1. Repair ECU Mazda 323 Diesel with ST93c56 Denso ECU and Mitsubishi Immo Box
Use this option to prepare the ECU for coding a new key
MERCEDES-BENZ:
1. Repair C,E class (inra-red) (Step 1/2) - ECU Motorola HC11E9 Lucas ECU
2. Repair Mercedes Benz (C and E Class) infra-red (Step 2/2) - Immo file Motorola HC05 Siemens
3. Sprinter Start Error PROBLEM Temic - Motorola HC08
4. Vito START ERROR PROBLEM Temic - Motorola HC05
5. Vito START ERROR PROBLEM Temic - Motorola HC08
6. Unlock ECU Sprinter Prepare ECU for coding ECU with 1 plug and 24C02 MEM
7. Unlock ECU Sprinter Prepare ECU for coding with 5 plugs and 5P08C3 MEM 95P08
8. Unlock ECU Vito Prepare ECU for coding with 5 plugs and 24C04 MEM
9. Repair A class ECU Siemens/VDO with 29F200 memory
10. START ERROR PROBLEM Sprinter 2.2 , 2.7 to repair damaged ECU, WSP must be OK ECU with 5 plugs and 5P08C3 MEM 95P08
11. Unlock ECU (prepare for coding) - EDC16, MEM 95320
OPEL:
1. Repair ECU - DELCO with HC11F1 MCU (2 plugs (red+white))
2. UNLOCK ECU (prep. for coding) - BOSCH DTL with 24C04 memory and 29F200
3. Repair ECU - DELCO with HC11F1 MCU (2 plugs (blue+grey))
4. Repair ECU Siemens Simtec 56.1 with 93C56 MEM
5. UNLOCK ECU (prep. for coding) Bosch - DTL 24C04 + 2x29f010
6. Repair ECU - Siemens Simtec 56.1 with 29F010 MEM - Remove Immo
7. Repair ECU - (1.7, 2.0) 16V - Turbo Diesel (Remove Immo)
8. Repair ECU - 1.2 8V Delco/GM with 27C256 MEM (Remove Immo)
9. Repair ECU - BOSCH Motronic based on 24c02 I2C MEM
10. Repair ECU - (2.5) Turbo Diesel Bosch - Opel/BMW 2 x 93C46 MEM (Remove Immo)
PEUGEOT:
1. Programm PIN Peugeot Sagem S2000
2. Calculate Peugeot 206/BSI - MEM 95160
3. Calculate Peugeot 206/BSI - MCU HC912
4. Calculate Peugeot 307/BSI - MCU HC912
5. Calculate Peugeot 307/BSI - MEM 95160
6. Repair ECU - BOSCH MP5.1.1 with 93C46 memory
7. Repair ECU - SAGEM S2000 with 95080 memory
8. Repair ECU - IAW 1AP.80 - Magneti Marelli with TMS374 MCU
9. Repair ECU - IAW 1AP.81 - Magneti Marelli with TMS374 MCU
10. Repair ECU - IAW 1AP.40 - Magneti Marelli with TMS374 MCU
11. Repair ECU - SL96 9 Sagem with TMS374 MCU + 1x28F512
12. Repair ECU - 2.3, 2.8 JTD BOSCH 0 281 010 484 with 5P08C3 MEM 95P08
13. Repair ECU - IAW 1AP.20 - Magneti Marelli with TMS374 MCU
14. Repair ECU - IAW 1AP.90 - Magneti Marelli with TMS374 MCU
15. Repair ECU - IAW 48P2.xx Magneti Marelli with 29F400 MEM (1.1 Engine)
16. Repair ECU - SL96 9 Sagem with TMS374 MCU + 2x28F512
17. Repair ECU - IAW 1AP.41 Magneti Marelli with TMS374 MCU
18. Repair ECU - IAW 1AP.43 Magneti Marelli with TMS374 MCU
19. Repair ECU - IAW 1AP.83 Magneti Marelli with TMS374 MCU
20. Repair ECU - IAW 8P.xx Magneti Marelli with HC11A8 MCU
21. Repair ECU - SAGEM S2000RPM with 95080 memory
22. Repair ECU *** PSA Johnson Controls - MEM 95160 memory, Remove Immo !
23. Repair ECU IAW 6LP2.02 - Magneti Marelli ST10F280 MCU, Clear Immo !
24. Repair ECU EDC16 Bosch EDC16C34, Remove Immo ! 95640 MEM
RENAULT:
1. Repair ECU - Magneti Marelli 5NR.xx - hybrid
2. Repair ECU - EDC15C3 - BOSCH with 5P08C3 memory 95P08
3. Repair ECU - DELPHI with 95080 memory
4. Repair ECU - LUCAS DCU3R with 25080 memory, Clear Immo!
5. Repair ECU - LUCAS DCU3R with 25080 memory, Remove immo!
6. Repair ECU - SIEMENS - SIRIUS32 with 29F200 memory
7. Repair ECU - SIEMENS - SIRIUS34 with 29F400 memory (Algo 1)
8. Repair ECU - Fenix 5 SIEMENS - with TMS374 MCU (TMS374C003A)
9. Repair ECU - SIEMENS - FENIX 3 with HC11E9 mcu
10. Repair ECU - Magneti Marelli - IAW5NR2.XX with 95160 memory, clear immo
11. Repair ECU - Magneti Marelli - IAW5NR2.XX with 95160 memory, clear immo
12. Repair ECU - Bosch - 1.9 DTI (2 plugs) with 24C04 memory e.g.
ECU - BOSCH 0 281 010 502 - 24C04 memory
ECU - BOSCH 0 281 010 442 - 24C04 memory
13. Repair ECU - Bosch - 1.9 DTI (1 plug) MSA 15.5 with 24C02 memory
14. Repair ECU - Magneti Marelli - IAW 6R.20 with TMS370 mcu
15. Repair ECU - Magneti Marelli - IAW 6R.30 with TMS370 mcu
16. Repair ECU - SIEMENS - SIRIUS32 (Engine 16V) with 29F200 memory
17. Repair ECU - Delphi - 1,5DCI with 95160 memory, Remove crash blockade
This solution removes crash entry - created after an accident.
18. Repair ECU - SIEMENS - SIRIUS35 with 29F400 memory
19. Repair ECU - SIEMENS - SIRIUS34 with 29F400 memory (Algo 2)
20. Repair Megane 2 steering lock with 24C04 memory
21. ECU - Bosch - MP 7.0 with 24C02 memory
22. Repair ECU - Magneti Marelli - IAW 8R.30 with HC11A1 mcu (Remove Immo)
ROVER:
1. Repair ECU - ROVER M.E.M.S - with 93C46 memory
SKODA:
1. Repair ECU - SIEMENS - SIMOS with 93C56 memory
TOYOTA:
1. Repair ECU - YARIS - Denso - with 93C56 memory
2. Programm - IMMO Keys for External Immo Box with 93LC66 memory and 4C Texas transponder
V.A.G.
1. Repair ECU - BOSCH with 24C04 memory e.g.
ECU - BOSCH 0 281 010 179 - 24C04 memory
ECU - BOSCH 0 281 010 407 - 24C04 memory
ECU - BOSCH 0 281 010 497 - 24C04 memory
ECU - BOSCH 0 281 010 199 - 24C04 memory
ECU - BOSCH 0 281 010 385 - 24C04 memory
2. Calculate ECU - BOSCH EDC16 with 95320 memory
3. Calculate IMMO - SIEMENS 5WK4 678-1H0 953 257 BB with HC05 MCU
4. Calculate IMMO - SIEMENS 5WK4 7740-6H0 953 257 B with TMS370 MCU
5. Calculate IMMO - VALEO 6X0 953 257 with 24C04 MEM
6. Calculate IMMO - VW LT with HC05X16 MCU
7. Calculate IMMO - White Box with C46A6 - 93C46 MEM, 4A0 953 234 F - f+g megamos
8. Repair ECU TDI (1 plug) Bosch - 24C02 MEM
9. Repair ECU TDI (2 plugs) Bosch - 24C02 MEM
10. Repair ECU - BOSCH EDC16 with 95320 memory (Remove Immo)
11. Repair ECU - BOSCH ME7.x(x) with 95040 memory (Remove Immo)
12. Repair ECU - Simos with 93C76 memory, Siemens, Remove Immo:eek:k:
tx-mafia
332
2,639
ImmoKiller v1.10
ImmoKiller v1.10
tx-mafia
332
2,639
ببخشید دوستان دیر جواب دادم
من خودم هم زیاد کار نکردم با این نرم افزار
اما برای پاک کردن کد سوئیچ 206 و بعضی دیگه از ماشینها استفاده میشه
برای بازسازی فایلهای ecu هم میشه ازش استفاده کرد
شما باید بوسیله پروگرام آی سی ecu رو طبق راهنمایی یا عکسی که خود نرم افزار بهتون میده بخونید
بعد از طریق خود نرم افزار بازش کنید و عملیاتی رو که میخواید روی فایل ecu انجام بدید بعد سیوش کنید و دوباره آی سی رو پروگرام کنید
