- 2007-05-09
- 5,023
- 106,558
با سلام :
اداپتور پروگرامر WILLEM ورژن 1-4 بنا بدرخواست دوست گلم اقاي majid_tech
به همراه نرم افزار مربوطه و فايل هاي شماتيك و PCB و راهنماي استفاده و مونتاژ كامل :
امكانات و ايپرام ها و فلش هاي ساپورتي :
Willem 4.1 flash eeprom programmer mod to read/write SPI. Modificações no Willem 4.1 programador para ler/gravar eeproms SPI:
Software willem PCB35A version 0.98x Work on Hardware PCB35,PCB45,PCB50
It Can't support PCB3B, PCB3B+,PCB3A, Enhance willem ...
You Can update software new version at
http:// www.sivava.com
Copyright by www.sivava.com
Ver 98D9 02/10/2008
- (PCB50 support VCC 3.6V for serial CHIP SPI FLASH+EEPROM by Open Jumper ( 3V6)
- (PCB45 with modify copper track VCC(5V) --- > VCC(3.6V)
PCB45(0.98D9) // TEST on CHIP (get ID,Read,ERASE.verify,Blank Check,Program)
CHIP 3.3V (vcc=3.6V) : EN25P16, MX25L1605, MX25L4005, W25X16
CHIP 5V : 25LC(AA)1024(5V)
SPANSION
S25FL004A/040A,S25FL008A,S25FL040A-T,S25FL040A-B,S25FL016A,S25FL032A
S25FL064A
WINBOND
W25X010,W25X020,W25X040,W25X080,W25X16,W25X32,W25X64
MXIC
MX25L512,MX25L1005,MX25L2005,MX25L4005A,MX25L8005A,MX25L1605,MX25L3205
MX25L6405
EON
EN25B05,EN25B10,EN25B20,EN25B40,EN25B80,EN25B16,EN25B32,EN25B64
EN25P05,EN25P10,EN25P20,EN25P40,EN25BP80,EN25P16,EN25P32,EN25P64
EN25D80,EN25D16,EN25F20,EN25F40,EN25F80,EN25F16
AMIC
A25L05P-B,A25L10P-B,A25L20P-B,A25L05P-T,A25L10P-T,A25L20P-T,A25L512
A25L010,A25L020,A25L040,A25L080;,A25L016,A25L032
pFLASH
Pm25LV512,Pm25LV010,Pm25LV020,Pm25LV040,Pm25LV080,Pm25LV016
Numonyx (ST)
M25P05,M25P10,M25P20,M25P40,M25P80,M25P16,M25P32,M25P64
M25PE10,M25PE20,M25PE40,M25PE80,
**M45PE10,M45PE20,M45PE40,M45PE80,M45PE16
M25PX80,M25PX16,M25PX32,M25PX64
*** SST
SST25VF512,SST25VF010,SST25LF020,SST25VF020,SST25LF040,SST25VF080,
SST25VF016,SST25VF032
ATMEL
AT25DF021,AT25DF041A,AT25DF081,AT25DF081A,AT25DF161,AT25DF321A
AT25DF641,AT26DF041,AT26DF161A,AT26DF321,
** AT45DF011D,AT45DF021D,AT45DF041D,AT45DF081D,AT45DB161D,AT45DF321D,AT45DF641D
** modify for pin out
*** next verison (1-2date)
Ver 098d7 (12/12/2005)
- Fixed get ID FWH/LPC windond W49V***,W39V***
- Fixed Prog. SST39VF160
- Add AT89S2051/4051
- Add AT89LP2052/4052
Ver 098d6 (26/09/2005)
- add PIC10F220/222 (41266A.pdf)
- add PIC12F506 (41258A.pdf)
- add PIC16F59 (41243A.pdf)
- Fixed Prog AT28C256 (Test on AT28C256-30PC)
Ver. 098D4 (13/08/2005)
- Add device ID,Menu,Table index :28F002/004/200/400BX-x (TSOP40A,TSOP48 8/16bit, PSOP44)
Ver. 098D3
- Fixed Program Config PIC16F8x, PIC16F62x, PIC16F87x
- Fixed ID PIC18F84A
(Test on PIC16F84, PIC16F84A, PIC16F627/628/628A, PIC16F872/877)
- Fixed Timming Programming PIC12C5xx (Run on Windows XP)
Test on PIC12C509JW UV erase), PIC16C505JW (UV erase),PIC12F509 (select device = PIC12C509A)
Ver 0.98D (04/06/2005)
- Fixed Write/read/verify EEPROM 18F4550
- Fixed Bug program PIC18F*** run on Windows XP/2000
(test PIC18F4539, PIC18F2680, PIC18F2431
PIC18F258, PIC18F4220, PIC18F4550)
- Add find OSCCAL 10Fx00, 12F50x, 12F6xx
(test PIC10F202, 12F509, 12F675)
- Fixed Program AT89C8253 (Want modify Adapter MCS-51)
(test on AT89S8253);
version 098c
-Add PIC microchip 14bit
PIC12F629/675, PIC16F630/676 ,PIC12F635/683,PIC16F636/684/688
PIC16F72/73/74/76/77, PIC16F737/747/767/777,PIC16F87/88,
rfPIC12F675x
PIC16F785/PS200
PIC16F716
-Add microchip 14bit OTP
PIC12C671,PIC12C672,PIC12CE673,PIC12CE674
PIC16C61/71
PIC16C62/64/65/73
PIC16C62A/62B/62C/63/63A/64A/65A/65B/66/67
PIC16C72/72A/73A/74A/74B/76/77
PIC16C620/620A/621/621A/622/622A
PIC16CE/623/624/625
PIC16C710/711/712/716
PIC16C773/774
PIC16C745/765/923/924
PIC16C925/926
PIC16C554/556/557/558
PIC16C432/433
PIC16C717/770/771/781/782
-Add PIC microchip 12bit (FLASH memory)
PIC12F508, PIC12/509, PIC16F510
PIC10F200, PIC10F202, PIC10F204, PIC10F206
PIC16F505, PIC16F506
PIC16F54, PIC16F57, PIC16F59
-Add PIC18F***
PIC18F242,18F248,18F252,18F258,18F442,18F448,16F452,16F458
PIC18F1220,18F2220,18F4220,18F1320,18F2320,18F4320
PIC18F6520,18F6620,18F6720,18F8520,18F8620,18F8720
PIC18F2331,18F2431,18F4331,18F4431
PIC18F6525,18F6621,18F8525,18F8621
PIC18F6585,18F6680,18F8585,18F8680
PIC18F2439,18F2539,18F4439,18F4539
PIC18F6410,18F8410,18F6490,18F8490
PIC18F2410, PIC18F2420, PIC18F2455
PIC18F2510, PIC18F2515 ,PIC18F2520, PIC18F2525, PIC18F2550, PIC18F2585
PIC18F2610, PIC18F2620, PIC18F2680
PIC18F4410, PIC18F4420, PIC18F4455
PIC18F4510, PIC18F4515, PIC18F4520, PIC18F4525, PIC18F4550, PIC18F4585
PIC18F4610, PIC18F4620, PIC18F4680
- Add Edit and FineTUNE value OSCCAL (PIC12F629/675, PIC16F630/676, PIC12F508/509/510, PIC16F505/506,
PIC10F200/202/204/206)
--------- Add Auto-calibration of the PIC12F6XX Internal RC Oscillator
- Add Edit config at address 0x2008,0x2009 (PIC12F635/683,PIC16F636/684/688,PIC16F785)
- Fixed Programming PIC All
- Test on chip
- PIC12F675, PIC16F676, PIC16F684 ,PIC16F767, PIC16F74
- PIC16F872, PIC16F876, PIC16F877, PIC16F873A, PIC16F876A,
- PIC16F84, PIC16F84A, PIC16F628, PIC16F628A, PIC16F819
- eprom PIC12C509JW, PIC16C505JW, PIC16C711JW, PIC16CE625JW
- PIC18F458, PIC18F4320, PIC18LF258, PIC18F4539
- PIC18F4550, PIC18F4231
- PIC10F202, PIC12F509, PIC16F54
- PIC12F629, PIC12F683, PIC16F630, PIC16F88, PIC12F635, PIC16F648A
- PIC18F1220, PIC18F4220, PIC18F2680
براي اپديت از لينك و راهنمايي هايي كه در متن فايل PDF موجود هست استفاده كنيد
با تشكر .
موفق باشيد .
Ver 98D9 02/10/2008
SPANSION
S25FL064A
WINBOND
MXIC
MX25L6405
EON
AMIC
pFLASH
Numonyx (ST)
*** SST
ATMEL
Ver. 098D3
version 098c
rfPIC12F675x
PIC16F785/PS200
PIC16F716
PIC16C61/71
PIC16C62/64/65/73
PIC16CE/623/624/625
PIC16C773/774
PIC16C925/926
PIC16C432/433
-Add PIC18F***
- Test on chip
با تشكر .
موفق باشيد .
886.5 کیلوبایت بازدیدها: 634
2 مگابایت بازدیدها: 630
آخرین ویرایش توسط مدیر:
