آموزشی: اموزش کرک پسورد لپ تاپ های مختلف
Service Manual
D e b u g g e R
13,682
176,855
iRanTK.iR
اين هم يک فايل iso هست که بايد روي يک سي دي خام رايت کنيد ، براي تعويض Service Tag و ريست پسورد هست ، توضيحات اانگليسي رو مطالعه کنيد / يا حق
What does this utility do?
This utility is used to re-program the system service tag on certain Dell Portable systems. The utility may only work on systems which already have a service tag programmed. If no service tag currently exists, the utility may return an error message and fail.
To program the service tag on a system that does not already have one:
- For Value-line systems:
Run EE-Value.exe /S=******X, where ******X is alphanumeric and all letters are capitalized.
- For SmartStep/Smart PC 200N/250N:
Run STAG_W1.EXE /W ******X, where ******X is alphanumeric and all letters are capitalized.
- For Molokai:
Run SERTAG.exe /W ******, where ****** is alphanumeric and all letters are capitalized.
- For all other systems:
Run ASSET.COM /S ******X, where ******X is the new service tag.
USAGE:
Boot from the diskette and follow the on-screen prompts to erase and program a new service tag.
See the comments in AUTOEXEC.BAT on how to automate the process.
General Information:
This diskette contains 6 main programs or program types:
1. SVCTAG.EXE
2. 6 varieties of EE-ERASE
- EE-CP.EXE
- EE-CPA.EXE
- EE-CPB.EXE
- EE-LS.EXE
- EE-LS2.EXE
- EE-VALUE.EXE
- STAG.EXE
- STAG_W1.EXE
3. 3 varieties of ASSET
- ASSET.COM
- EE-VALUE.EXE
- STAG_W1.EXE
4. NICSET.EXE
5. FDD_RCL.EXE
6. SVCTAG.INF
1. SVCTAG.EXE is called from autoexec.bat. It is a utility that determines if the system on which it is being executed is supported by the disk. If so, it determines which type of system it is, using the system ID byte. This information is gathered from either SMBOIS calls or XBIOS calls, if SMBIOS fails. The utility also uses these calls to determine if a service tag is currently programmed on the system. If one isn't programmed, there is no need to run EE-ERASE so the utility goes directly to the ASSET program.
2. Based on the information gathered, SVCTAG.EXE launches the appropriate version of EE-Erase. Each of these utilities can be run stand-alone. For EE-CPA.EXE, the -forcetype command line switch may be required.
3. The appropriate version of ASSET program is then launched. SVCTAG.EXE first asks the user the enter the new service tag (twice for verification) then passes that value to ASSET when it is launched. The ASSET programs can be run as a stand-alone utilities as noted above.
4. NICSET.EXE is launched by SVCTAG.EXE after EE_ERASE if the system is a Latitude C610 or Inspiron 4100. NICSET is needed in order to unhide and enable the onboard NIC, which is disabled by EE-ERASE.
5. FDD_RCL.EXE is the launched from AUTOEXEC.BAT after SVCTAG.EXE. It performs a Recalibrate operation on the floppy diskette drive. The purpose of this utility is to ensure the FDD head is moved to track 0 in preperation for transport. It is important to power off the system immediately after this utility is run in order to guarantee the head remains at track 0.
6. SVCTAG.INF is the text file contains vendor name, system id, ee-erase, erase options, asset and asset options. This file is processed by svctag.exe. The program goes through this file line by line and searches for system id and BIOS vendor string which match the system ID and BIOS vendor string read from the system on which the utility is being run. If a match is found, the corresponding line will be parsed and the executables and command line options from that line will be used to erase and program the service tag.​
[hide]
مشاهده فایل‌پیوست Dell Bios Reset.rar
[/hide]
Service Manual
D e b u g g e R
13,682
176,855
iRanTK.iR
How to Set or Change a Dell PowerEdge Service Tag
Got a Dell PowerEdge that you replaced the motherboard on, and now it doesn’t have a service tag? Reset it with the asset.com tool, which I’ve conveniently packaged as both a floppy disk image and an ISO for those of us in need. They both use the Windows 7 boot disk DOS and asset_A209.com from ftp.dell.com (renamed to asset.com).
Once you boot from these you can set the service tag with:
asset /s <service tag>​
You can also set the asset tag with:
asset <asset tag>​
Or clear the asset tag with:
asset /d​
[hide]
مشاهده فایل‌پیوست dell-asset-and-service-tag.rar
[/hide]
A.R.T
3,172
46,420
یکی از مشکلاتی که عموما در انجمن مطرح شده فراموشی پسورد لپ تاپ بوده.
برای حذف پسورد این گونه لپ تاپها چند راهکار وجود داره.
در مدلهای قدیمی که فاقد ایسی سیکیوریتی بوده با برداشتن باطری تا مرز 72 ساعت (اغلب در مدلهای اچ پی) پسور ریسیت میشود
اما اکثر مدلهای جدید دارای ایسی سیکیوریتی هستند
و این بخاطر امنیت در هنگام مشکلاتی مانند سرقت و غیره می باشد که این گونه مدلها دارای این ایسی امنیتی بوده و همین امر باعث شده تا امنیت بیشتری نسبت به رایانه های شخصی(PC یا همون رومیزی داشته باشد)
که برای حذف پسورد باید هم ایسی سیکیوریتی را خام کرد و هم گاها بایوس پروگرام شود
و همچجنین از نرم افزارهایی که با گرفتن سرویس تاگ و کدی که بعد از سه بار اشتباه وارد کردن پسورد داده میشود را به نرم افزار داده تا پسوردی در اختیار ما داده شود تا بتوان از سد پسورد رد شد
اما یکی از راهکارهایی که به علت ریسک ، کمتر استفاده میشود و دیگر نیاز به در اوردن ایسی هم نیست
اتصال دو تا از پایه های ایسی هست( این ایسی معمولا در کنار ایسی بایوس هست)
که حتما باید تجربه و مهارت کافی داشته باشید
مثلا در ایسی شماره 24C02 باید پایه 1و 6 را اتصال بدهید( در زمان روشن بودن دستگاه)
و دیتاشیت ایسی هم داشته باشید
مهمترین ایسی هایی که عموما در قالب ایسی سیکیوریتی قرار میگیرند شامل:
24c01
24c02
24c03
24c04
24c08
24RF08
2408
24c16
24c164
93lc46
93c56
0446
ATMEL
اگر شماره ایسی شما در بین این شماره ها نبود می بایست در اینترنت جستجو کنید و دیتاشیت مربوط به ان را پیدا کنید
در لپ تاپها Cmos در داخل I/O گنجانده شده اما اغلب رایانه های رومیزی در داخل چیپ جنوبی هست
در اخر تمام فایلهای مربوط به ارائه پسورد در تمام مدلهای رایج به پیوست ارائه میگردد
http://www.irantk.ir/private.php?do=showpm&pmid=431596#ixzz31npUnudI
[hide][/hide]
mosaffa
1,277
7,206
صومعه سرا
mosaffa
1,277
7,206
صومعه سرا
ضمن عرض سلام . اگه امکان داره در مورد استفاده از این سایت روسی کمی بیشتر توضیح بدید . ممنون از لطفتون
سلام وادب
با استفاده از مرور گر کروم اگر صفحه رو باز کنید میتونید به زبان انگلیسی ترجمش رو ببینید.در پایین صفحه یک مستطیل هست که نوشته Enter the code here:
شما باید ارور کدی رو که لپتاپ بهتون میده رو اونجا وارد کنید وgenerate رو کلیک کنید .بعد بهتون مستر کد رو میده(البته اگر لپتاپ در بازه تعریف شده خودش باشه).
